ROM conversion for 80mm Summilux
ryee3
Want to send my lens to get ROM conversion and to check on the focusing when using it with my DMR. Do I need to send the DMR with the lens? Or just the lens?
Where would you suggest to send it, Solms or New Jersey or to one of the solo repair experts? Anybody know the approximate cost? Thanks!:)
You would want to send your lens to NJ if you are in the USA. I wouldn't send your DMR but you could call and ask. If your DMR was the problem you would have trouble with all lenses. Are you sure you are having a problem with the 80mm lens? The 80mm Summilux is a difficult lens to focus. The 1.4 apperature is a little soft in the viewfinder making it difficult to see accuratly and the shallow depth of field leaves no room for error. I struggle with mine all the time but my lens is fine.
