Anyone using the protector case #14879?
sps
Here's a link:
Leica Camera AG - Photography - Camera Protector for M8
I bought a couple as an alternative to the grip but I think the grip is better. They are nicely made, provide the finger and thumb rest but getting to the card and battery is a bit of a hassle. They make the thumb wheel on the back more difficult to use.
There's no attachment at the bottom, the sides are cut to wrap around the strap lugs so that it effectively hangs off the strap lugs. It's quite a tight fit and would likely stay in place without them.
It provides a decent grip for the camera plus of course it's protected when you put it down on something.. The main downside is that it has to come off to replace the card or the battery.
From the point of view of holding the camera in use, the grip is better, but this provides protection which the grip does not, so there's room for both. It's about £55/€80/$110, so not too expensive. The full case, which is more hassle - because you cannot remove the "floppy" bit - is more than double the price.
