Theodor Heinrichsohn Posted January 23, 2007 Share #41 Â Posted January 23, 2007 Advertisement (gone after registration) 1. M8, second generation 2. No problems - up to now Teddy Link to post Share on other sites More sharing options...
sean_reid Posted January 23, 2007 Author Share #42  Posted January 23, 2007 I have 3 and trying to get all my facts straight but every camera has had a battery failure of some sort . Personally i think there are some bad batteries or the voltage is dropping to low and it fails. This is not a camera issue but a battery issue and it's performance at less than full charge  Hi Guy,  Thanks. Once you remember what happened to them, it would be great if you could answer the poll questions so that I can have the data.  Best,  Sean Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted January 23, 2007 Share #43 Â Posted January 23, 2007 I will get my memory in order. LOL Sign of age Link to post Share on other sites More sharing options...
dratt Posted January 23, 2007 Share #44 Â Posted January 23, 2007 1. One M8 with 1.09 preinstalled (=second generation) 2. Yes, twice 3. Yes 4. - 5. - 6. - 7. - 8. I belive both times the battery was rather full. Â I did not notice static in those cases but both times it was just after getting from inside to an outside area (maybe 5 C) but at the same time the failure did not occur when taking the first picture but after a couple of shots. In fact this happened both times when I was doing a number of shots (4-5) in a rapid sequence (in single photo mode) and I noticed afterwards when the camera was working again that the last photo had not been saved on the SD-card. This made me think (and this is my hope) rather of a firmware problem where the software was crashing which Leica might be able to fix with an update rather than a hardware problem. Â Tobias Link to post Share on other sites More sharing options...
Hans Roggen Posted January 23, 2007 Share #45  Posted January 23, 2007 1: One (second genreation) 2: No  Regards  Hans Link to post Share on other sites More sharing options...
jaapv Posted January 23, 2007 Share #46 Â Posted January 23, 2007 I have 3 and trying to get all my facts straight but every camera has had a battery failure of some sort . Personally i think there are some bad batteries or the voltage is dropping to low and it fails. This is not a camera issue but a battery issue and it's performance at less than full charge My feeling to let' get tis speculation to another thread Link to post Share on other sites More sharing options...
bnelson Posted January 23, 2007 Share #47 Â Posted January 23, 2007 Advertisement (gone after registration) 1. One M8, second generation (1.09) owned for 3 weeks 2. No problems encountered as of yet Link to post Share on other sites More sharing options...
Cindy Flood Posted January 23, 2007 Share #48 Â Posted January 23, 2007 1. One M8 used continuously since early November, 2006 2. Yes, first generation...no software or hardware update. 3. Battery was about 1/2 used. Took a shot. Put M8 back in neoprene case. About 5 minutes later, I tried to take a shot and it was dead. Pulled battery and re-inserted. No go. Put in fully charged spare battery. No go. Removed and re-inserted spare. Started up. Noticed that M8 must have gone completely dead. I was shooting .DNG as I always do, and now it was set to .Jpgs. This all happened at very high altitude in the desert (way up in the mountains.) We were in a restaurant/bar. Static electricity is very possible in these conditions. Never happened again. 4. Yes 8. Half Link to post Share on other sites More sharing options...
fotografr Posted January 23, 2007 Share #49 Â Posted January 23, 2007 I'm not sure if you want my response because you say, "owned for more than a week," and my M8 failed during the second day of use. I'm going to answer your questions anyway. Â 1. Zero, but I owned one for 2 days before it failed. 2. Yes, the camera failed as described in "D" and was 2nd generation, Firmware 1.09. 3. No 4. No 5. No. The interval was about 15 hours. 6. Yes, and yes. 7. Not yet. It was just received by them yesterday. 8. I did not note battery level, but it was near full charge. I shot less than 50 images total. There was no static electricity in the area. Link to post Share on other sites More sharing options...
khanosu Posted January 23, 2007 Share #50 Â Posted January 23, 2007 Hi Sean, too late to edit my post (#2) above; just want to add that my camera is 2nd generation. Â Furrukh Link to post Share on other sites More sharing options...
chrism Posted January 23, 2007 Share #51 Â Posted January 23, 2007 1) One 2) No (second generation) Â Chris Link to post Share on other sites More sharing options...
xrogers Posted January 23, 2007 Share #52 Â Posted January 23, 2007 1. One, first generation, since 11/06. 2. No. Â Clyde Link to post Share on other sites More sharing options...
carstenw Posted January 23, 2007 Share #53 Â Posted January 23, 2007 1. One M8, first 1.06, then 1.09, full upgrade. 2. No. Link to post Share on other sites More sharing options...
scott kirkpatrick Posted January 23, 2007 Share #54  Posted January 23, 2007 1. one (2nd generation, but only in my possession for 1 1/2 wks, 500 exposures)2. no problems  scott  Let me qualify that very slightly. Near the end of the first battery charge, I had a slow startup, turned it off and on, continued shooting but discovered that I had reverted to all Jpeg. I reset things the way I wanted them and this hasn't happened again. Time of day clock was not affected.  scott Link to post Share on other sites More sharing options...
johnbuckley Posted January 23, 2007 Share #55 Â Posted January 23, 2007 Sean: Have owned one M8 (though it is now in Solms...) Purchased November 6th. Waiting for it to be sent back to me. Â Have twice had battery drain issues, but not precisely the scenarios you've described here and before. Â In both cases I have had a battery unaccountably drain -- as from three bars to a dead camera in the blink of an eye. Â Recharging battery has fixed things, at no small opportunity cost. JB Link to post Share on other sites More sharing options...
teehas53 Posted January 23, 2007 Share #56  Posted January 23, 2007 1. One M8, Gen. 2, FW 1.09, delivered 12-28-06 2. No  I have only experienced one unexpected "event" - strange behavior of the LCD panel. Only happened once, within the first hour of use. Hasn't recurred.  Tom Link to post Share on other sites More sharing options...
Fotomiguel Posted January 23, 2007 Share #57 Â Posted January 23, 2007 1. I own one M8 for the last 20 days. 2. Yes. 3 times. my m8 is second generation. 3. Yes. It always came to normal after remove briefly the battery. 8. I didn't notice the battery level. I didn't notice static electricity but perhaps there was. Thank you Sam! Link to post Share on other sites More sharing options...
peterv Posted January 23, 2007 Share #58  Posted January 23, 2007 1. one M8  2. yes, second  3. yes  8. battery was full, I don't know about static electricity, but I'm in a wheelchair with rubber wheels.  Thanks for all your help, Sean, good luck! Link to post Share on other sites More sharing options...
bradreiman Posted January 23, 2007 Share #59 Â Posted January 23, 2007 1 first gen M8 with 1.09 firmware. locked up once where the shutter button did nothing and the viewfinder leds were not present. removed and replaced the battery(which was fullish) and the camera has worked fine ever since. i shoot alot everyday...b Link to post Share on other sites More sharing options...
herbkell Posted January 23, 2007 Share #60  Posted January 23, 2007 I own one M8  It is second generation with 1.09  Freezing has happened twice -  Both times rectified by removing the battery (almost full) and replacing  Second malfunction took a few tries before it would revive the camera. I finally kept it out for about half and hour and it worked OK when I replaced it. Link to post Share on other sites More sharing options...
