Gray Dot on Bottom of Lens case
jtbthree
My new 50mm Summilux 1.4 ASPH lens came with the normal soft black lens case, but had a very large light gray dot on the bottom of the lens case (painted on the leather, not a "sticker") - does that signify anything, like being retrofitted with the 6-bit coding???
It's for writing the focal length / aperture of the lens on, so that if you have several similar sized lenses stored in a bag, you know which one is which.
I've always assumed it was an homage to the white dot on the film M's shutter that's used for spot metering.
It's for use in the factory so that when hundreds of leather cases are sitting side by side it's easy to see which ones are the wrong way up.
Otherwise they'd have to pick each one up and work it out by the position of the zip.
Pete.
I thought that they were added in the days of earlier film cameras. So that if your shutter tore, you could repair it in the field by cutting a new one out of the base of a lens case that included the metering patch. :) (Provided you were carrying your Leica 'Solms camera knife' with all of the little thingamibobs, of course. :D)
