Anyone using the R9 and DMR in cold weather?
vickko
Thanks all
Just took it out again, after warming it up in the house (while I had lunch).
Yep, cold weather makes the motor miserable. At least now I know the failure mode.
Half an hour at -10 degC and the motor was getting a bit intermittent about advancing the shutter.
The battery seems to be holding out, although it's been displaying "flat" all day (i.e. since morning).
Over 300 frames so far, which I hear is pretty substantial for the old DMR batteries.
....Vick
... The battery seems to be holding out, although it's been displaying "flat" all day (i.e. since morning).
That's quite good for an "old" DMR battery. I haven't taken mine out in weather much below 25 degrees F. The battery display told me they were half discharged but they kept working longer than I expected. No black exposures.
After Michel Bass rebuilds the batteries last substantially longer; I was in cool weather all yesterday (~40 degrees F) and didn't need more than one rebuilt battery pack.
Vick,
It's more likely to be the battery that's the problem than your R9/DMR because cold affects battery capacity, ie the amount of current it can deliver to the camera.
Lifting the mirror and re-cocking the shutter will put the biggest load on your battery so there may not be quite enough energy in the battery to do it regularly in cold conditions with an ageing battery, especially if taking shots in quick succession. (Even a short interval between shots will let the battery recover a little as it will have time to recombine its chemicals to produce a little more energy.)
Going back into the warm will help the battery while its in the warm but as soon as it gets cold again its capacity will drop significantly, no matter how freshly charged it is. Try to keep your batteries warm by keeping them close to your skin and they should behave better. Keeping the R9/DMR would be helpful but beware of condensation going from cold to warm.
Pete.
Thanks all
....Vick
Before pushing the shutter release button swing out the quick wind lever and leave it "open". That requires cocking the shutter by hand after the shot but it saves a lot of battery power.
krauklis
Yes, but the DMR batteries are not terribly sensitive to cold, probably because of the body mass around them. This suggests to me that they are running down. You might consider geting a couple rebuilt.
