Need help to have a happy Leica Cristmas...
If it comes off, it possibly won't focus properly.
That model was specifically designed for use on a 1950s M3, which didn't bring have 35mm framelines. The additional "goggles" enlarged the viewfinder image so that the 50mm framelines could be used instead.
I would see if I could get my money back, if I were you. Sorry!
Edited by andybarton
I bought a summaron to attach to my Nex, but I cant work out how to remove the view finder attachment. Oh no - It does come off... doesn't it?
Thanks in advance-Mark
Unscrew the kurnled head screw on top of the viewfinder and next slip out it from the front,
Thanks for that! I undid that screw and tried to remove it, but it didnt budge - is there any trick?
Push, wiggle, wiggle, wiggle, curse, wiggle, wiggle, curse-curse, PUSH, WIGGLE, WIGGLE - CHING! Ah, got it!
The art of gentle persuasion.:rolleyes:
Pete.
Thanks. I was just wondering if it would still focus to infinity.
I would have thought infinity would be allright?
Its the cam angle which is different to non goggled lenses, and thats irrelevant to the NEX, and the Panasonics too, I'll try my Summicron on the G1 when I get home after Christmas.
Happy Christmas to all, Gerry
May be you cannot turn it to lock due to the handling protusion.
I think not (Nex is vaguely intriguing me and I made some considerations about...;))... the std. 18-55 lens has a diameter of 62mm... Nex body is 58,8mm high... Summaron 3,5 is around 51-52 diameter... the infinity lock protrudes no more than 5mm from the collar... ought to result something around these two rough photoshoppings (with two other Summarons, indeed...)
Edited by luigi bertolotti
I mean with the GOGGLE on
Still no luck .... It feels like there is a spring inside, because the goggles return to the same position when I let go. There is a small half circle in the back of the goggle where is meets the lens (beneath "Made in Germany") - do I need to insert something in there?
If its like the DR Summicron,there is a ball bearing catch, and the shap[ you see helps it ride over the ball bearing, gentle peruasion should do the trick.
Gerry
It is strange that you have been able to remove the screw usualy it stops at the release point.
can you post a pict about this screw may the end part is broken and stays in the goggle so it stays stuck.
see how it is unmounted :
