Not sure this is what Leica had in mind for the M9 Titanium's market positioning...
sandymc
Sandy I think that you are right, I suspect Leica Camera don't mind the higher profile brand exposure as desirable objects at all.
The M9 looks almost inexpensive compared to some of the things on that list though!
I want the helicopter. I wonder if you can get it with APO ASPH windows.
... I want the helicopter. I wonder if you can get it with APO ASPH windows.
I think that option is available only if they've got enough anomalous partial dispersion glass left over from the glass speakers. ;)
Cute when breaching, but judging from the video, Seabreacher hasn't quite mastered the shark's elegance at re-entering the water. :p
I'll take the dome house. That does come on a turntable, doesn't it, to make best energy use?
Oh, and this seems to be the V-Lux 20 version of the dome: Mongol Yurt (Ger) - Mongolian House Yurtas or Houses from Mongolia Gers [Yurta].
Edited by ho_co
Oooh, I like this list. You land at your oceanfront Domehouse in your Mercedes Eurocopter, after having taken aerial photos with your titanium M9. After a quick blast through the sea in your shark machine, you relax in front of your 152 inch HD 3D plasma TV which uses glass speakers.
Am I the only one who thinks a Kid's Walker exoskeleton would be the bomb???
The aircraft balcony is probably the worst idea ever. If you need to use anything on board that requires a moderate amount of electricity (i.e. interior lighting), you'd need to turn on the auxiliary power unit. Then you'd be blasted with 130dB of high pitch jet engine noise and breathing jet fumes coming out from the tail. That is, unless you can plug the aircraft into some ground based power supply (which is not available in most deserted airstrips). So pretty much if you can get power, it probably means you're at a well equiped airport that has aircraft moving around nearby, making lots of noise and you'd be breathing in nasty jet fumes either way.
