macusque Posted January 19, 2007 Share #1  Posted January 19, 2007 Advertisement (gone after registration) I just received the Burzynski tripod collar for Leica 100 Apo-Macro.  I'm impressed by its quality. Wonderfully made, very solid, much more than the discontinued STA-1 plastic tripod collar from Leica. Smooth rotating and tight lock. The baseplate seems Arca-style, although I don't have my B1 to check as I sent it for repair, so maybe there's no need for an additional quick release plate. It has also a low profile which helps in making the system rock solid. The only "drawback" is that the collar hides the dof scale, which I never use anyway...  Burzynski make it for many lenses (also Canon and Nikon) including the 180 Apo-Elmarit and 80-200 Vario-Elmar. They don't seem to share the same model though. The tripod mount is made of two pieces. An external one, metal, which includes the baseplate and locking mechanism; and an "internal" one, a plastic collar which you need to lock on the lens tightening a little screw. The metal ring then will slide on the plastic collar and you can easily remove it.  Maybe lenses that have a similar barrel's diameter where it attaches (like the 180 Apo), could share the same tripod-collar and it would be sufficient to buy only the correct plastic ring. I'll ask them.  The tripod collar makes the aperture ring a bit more difficult to access, but overall it's not bad. I guess it would be better on the 180 Apo, because the lens has a smaller barrel just ahead of the aperture ring.  Anyway at 150 € including German VAT it is not utterly expensive, at least for Leica standards. You can find it at Isarfoto Bothe GmbH, from what I understand the only distributor for Burzynski products: https://www.isarfoto.com/cms.php/_pid:25238,l:2397,pp:0,ps:az/en/0/Produkt.html  Highly recommended Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/13919-tripod-collar-for-100-apo-macro-180-apo-and-80-2004/?do=findComment&comment=146916'>More sharing options...
johnkuo Posted January 19, 2007 Share #2 Â Posted January 19, 2007 Very nice. I have the 100 and 180APO, and can use this. But the shipping cost to USA is 119EUR if I didn't misread it. Link to post Share on other sites More sharing options...
macusque Posted January 19, 2007 Author Share #3  Posted January 19, 2007 Ouch!  You are right John, US shipping is 119 €... maybe you could ask them for a cheaper solution, like UPS standard.  Btw, how do you like your 180 Apo-Elmarit ?  I have the 180 Apo-Telyt, but I'm thinking to "upgrade" to the latest Apo-Elmarit, which accepts the 1.4x, making for a nice portable combo when I don't want to carry the 280/4 Apo. It focusses also closer than the Telyt. Link to post Share on other sites More sharing options...
johnkuo Posted January 20, 2007 Share #4 Â Posted January 20, 2007 I am very impressed with the 180/2.8APO. The internal focus is extremely smooth, and the image quality is fabulous. I read that the optimal aperture for this lens is at wide open. It's also very usable handheld. I think mine is the older one that does not accept the 1.4x. I don't have experience with the 180 apo-telyt, but if you like your 280/4, then you will love this 180. Link to post Share on other sites More sharing options...
wparsonsgisnet Posted January 20, 2007 Share #5 Â Posted January 20, 2007 Look how small the R9 ends up looking! Link to post Share on other sites More sharing options...
robsteve Posted January 20, 2007 Share #6 Â Posted January 20, 2007 Marco: Â I just posted some 180mm APO comparisons in another thread. The STA-1 collar will fit the 180mm APO-Elmarit. I think the STA-1 got discontinued becase the grip on the R8 or R9 would hit it and lot allow it to spin 360 degrees. Link to post Share on other sites More sharing options...
carstenw Posted January 20, 2007 Share #7 Â Posted January 20, 2007 Advertisement (gone after registration) Neat collar, but perhaps overkill for the 100. I love how that lens extends forever and two turns Link to post Share on other sites More sharing options...
macusque Posted January 20, 2007 Author Share #8 Â Posted January 20, 2007 John, Â thanks for your feedback, do you find it balances well when handholding ? Â Â Rob, Â I read your thread about the Elmarit vs Telyt. Thanks a lot ! Â Â Carsten, Â the 100 Apo balances very well on the DMR and the tripod collar is indeed overkill if maximum stability is what you are after. But I bought it mainly to allow the rotation of the framing without touching the ball-head. This is very convenient at close distances where changing orientation often shifts quite a bit the framing and you almost always need to compensate changing the tripod position. Link to post Share on other sites More sharing options...
