IR-CUT filter on 15 Voigtlander
macusque
In search for a solution to mount an IR filter on the 15 CV, I measured the hood’s inner diameter and I realized that maybe a 37mm filter could have been positioned inside the integrated hood, just in front of the frontal element.
I ordered a B+W UV/IR-CUT F-PRO 37mm and this week I received it.
I "semi-glued" it using a thin layer of black silicone on the filter ring, then gently pressing the filter in front of the lens.
The frontal element of the 15 protrudes, so the filter would touch it in the center, but the silicon layer adds just enough space to separate them.
Silicone acts like glue but it's easier.. well.. less hard to remove.
It's not an "elegant" solution, as if you want to remove the filter you'll end with cleaning the lens from the silicone around the glass, but giving I have only the M8 as rangefinder I don’t need to remove the filter anytime soon.
Images of the filter:
  • Replies 63
  • Created
  • Last Reply
The filter works correctly in removing the IR frequency, black of the speakers cover is black and blue of the big pillows is correct.
There’s the usual drift toward cyan at edges, but curiously not too much, considering the focal lenght.
I need to test more but it actually seems to show less than my 21 Elmarit asph.
There’s no vignetting from the filter, its mount doesn't gets into the framing.
This is wide open, showing the natural vignetting of the 15 CV (not too much anyway and it can be eliminated with +25 setting in PS).
You can notice also the cyan drift, again not too much evident considering it’s a 15 mm.
neat, but I wonder if I'd want an IR filter on my CV15 as I will be using it for landscape and other outdoor sun lit scenes where IR is a minimal issue. But if I wanted it for tungsten light, I'd try it! best....peter
I agree with Marco, you only have to think of things that show up in IR pictures to know that an IR filter is required most of the time - foliage is the prime example, which will show up in many landscape shots. If you don't think you need an IR filter, you are likely fooling yourself.
Neat solution, Marco, and interesting that it doesn't vignette.
Actually at the bottom of the hill, hidden in the image by more modern buildings, there's a roman amphitheater (Teatro Romano) which is still used as open theater in summer.
Just beautiful and it shows how ancient romans put many efforts in the "sound/acoustic department".
It's over two thousand years that those stones do their job and they still do it outstandingly well, something we could only dream of in this digital era :)
Brilliant! Much more elegant that the filter adaptor suggested at CameraQuest (though a little more permanent!)
Chris
Indeed Chris,
I thought about that solution too but I didn't like the idea to permanently attach a big 77mm filter in front of this tiny lens, which is very portable indeed.
Also, it costs almost nothing... 37mm filter apart, which is 50 € anyway :)
The silver version is not F-PRO, I received one last year (labelled "Digital" if I recall well) and IMO it is slightly less effective and it induces a very slight flare in some conditions.
The F-PRO instead is perfect from my experience, no more flare or ghosts than with the naked lens. :)
I just tried the 39mm 486 filter and it too fits inside the Voitlander 15mm hood.
Robert, did you manage to mount it without the silicone, maybe using a tape on the ring to make it more tight in place ?
That would be an even better solution indeed !
Hi Marco,
It would be interesting to see what the results would be like if you could hand-code a 9cm Leitz adapter with the 21/2.8 Elm. code and try it with your 15 plus filter.
Cheers,
Sean
Hi Sean, with "9cm Leitz adapter" you mean a particular screw - to - M-mount adapter ?
I use the one from Voigtlander and indeed it seems too small to accomodate the sharpie method.
Maybe the Leitz adapter is wider ?
