Recently Browsing 0 members
No registered users viewing this page.
Similar Content
By Stealth3kplIf you have one, why not try this?
I'm slowly making my way through this YouTube page and it's very enjoyable.
Pete
By gwpicsI am just working through some transparency work and scanning it on to the computer. I was particularly pleased with this one which was taken in 1999 on Kodachrome 64 using a Leica M6. Scanning was with a Plustek 8200i, and post was with LT Classic.
I think it is amazing how the work we have just put away into a filing cabinet etc. has stood the test of time, and before there is "ah, well it is Kodachrome" some Fuji Provia RDP is just as good.
Gerry
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! -
By IkarusJohnPlease excuse me if this has already been covered. I did a search and couldn't find anything on topic.
I have about 30 years of slides and negatives, 135mm and 6x6 formats. The results I'm getting from my Epson flatbed scanner and the 135mm scanner (I forget its name) are okay, but I'm wondering if I might get better results if I use my SL(601). Is this correct?
Can anyone advise if this is worth doing, what I need equipment wise (presumably some sort of holder and a uniform whit background) and if it is feasible to photograph negatives as well as slides?
Or am I wasting my time?
Cheers
John -
By Martin BWant to share my experience here to install two scanner related Silverfast 8 software packages on the same PC which allows to work with two scanners. I am currently using the Plustek 8200i scanner with Silverfast 8 Ai Suite and the Epson V850 with Silverfast 8 SE Suite. The start page of the software has a dropdown menu to select from multiple installed programs/scanners, but it is not straight forward to get there, and the current manual has nothing in there how to correctly install two or more Silverfast 8 versions for different scanners:
1. Do not install Silverfast 8 from the CD - the versions are not the most actual ones, and you can only run Silverfast 8 for two (or more) scanners with exactly the same updated version. Do not try to install from the CD and do not use the update function within the program at this point - it won't work correctly and will only lead to hiccups with the other version.
Also, you need to install both Silverfast 8 versions into the same hard drive directory to make them work in parallel.
2. Download the most actual versions directly form the Silverfast home page. To do this, registration of the software is a requirement. After registration, you need to enter the provided serial number which came with the original CD of the program - do not lose this number! This allows you to get on the Silverfast website with downloadable software versions for the specific program version (for example SE Pro) which was purchased most likely in combination with the scanner. Download the latest version into a directory to install from on the hard drive. Repeat the whole process for the Silverfast version of the second scanner - register it also, enter its serial #, and download again the latest version - it must be the same version code as the first one! - of this specific Silverfast 8 version.
3. Choose any of the two (or several) downloaded Silverfast 8 programs to be installed in a provided directory. After installation, select the other version to have it installed into the same directory as the earlier installed version. Then start the program with the provided Silverfast 8 desktop link - it will open the start page (assuming the scanner(s) are turned on) and have both scanners in the drop-down list to select from. After selection, the specific version of Silverfast 8 fitting to one of the scanners will start.
4. Updates in the future. I didn't experience this myself yet, but I asked this question to the support team of Silverfast. Supposedly you can run from now on the internal update function which will now automatically recognize that two (or more) Silverfast versions were installed in the same directory. I was told that there is no need to download the latest upgraded version again directly from the homepage. -
By duotonesFirst, Happy New year.
within my manual for the M10- on page 172- automatic Bracketing.
as I look at the picture on that page it Differs then what is on my camera.
On your M10 do you have within the Drive mode ' exposure bracketing' an automatic line 'A forth line"
I have the first three but not the forth line in my M10?
I'm was trying to do some HDR.
Please advise.
