scott kirkpatrick Posted January 14, 2007 Share #1 Posted January 14, 2007 Advertisement (gone after registration) I understood that a nice accidental feature of the lens coding was that if you pressed the frame lever to bring up the wrong frame, the camera would stop recognizing your lens, even if recognition was enabled. Well, maybe that was true with firmware 1.06, but it doesn't happen with the 1.09 that came with my new M8. I put on the 28/2.8 and it showed up in the EXIF in pictures taken with the frame preview lever in all three places. Further more, the vignetting corrections were independent of the frame prview position. Don't have other coded lenses or lenses coded up just yet. Jono Slack, or somebody else with the older TriElmar -- does the EXIF show the correct focal length for each setting? Under 1.09 only or already at 1.06? thanks, scott Link to post Share on other sites More sharing options...
Advertisement Posted January 14, 2007 Posted January 14, 2007 Hi scott kirkpatrick, Take a look here Some forum folk theorems need checking. I'm sure you'll find what you were looking for!
jaapv Posted January 14, 2007 Share #2 Posted January 14, 2007 On my 1.09 camera it still works the other way around; the camera only recognizes the Biogon (hand-coded) when I push the frameselector lever. And the Tri-Elmar old shows up all three focal lenghts correctly. Link to post Share on other sites More sharing options...
danielt Posted January 14, 2007 Share #3 Posted January 14, 2007 On my 1.09 camera, Tri-Elmar 1st version coded, Elmarit 28 coded, and Biogon 35 f2 coded manually, shows up all focal lenghts correctly, Link to post Share on other sites More sharing options...
marknorton Posted January 14, 2007 Share #4 Posted January 14, 2007 On mine, the Tri-Elmar works as expected with each individual focal length being recognised (unlike the compromised 16-18-21 lens). Put a 28mm Summicron on the camera and the correct focal length is reported, irrespective of the frame selector lever position, as Scott has reported. [This is of course different from the previous version which only recognised the lens when the lever is in the correct position - might make it easier to manually code CV and Zeiss lenses] So it looks like the camera is only looking at the lever position when the lens code indicates it should. Link to post Share on other sites More sharing options...
sean_reid Posted January 14, 2007 Share #5 Posted January 14, 2007 I understood that a nice accidental feature of the lens coding was that if you pressed the frame lever to bring up the wrong frame, the camera would stop recognizing your lens, even if recognition was enabled. Well, maybe that was true with firmware 1.06, but it doesn't happen with the 1.09 that came with my new M8. I put on the 28/2.8 and it showed up in the EXIF in pictures taken with the frame preview lever in all three places. Further more, the vignetting corrections were independent of the frame prview position. Don't have other coded lenses or lenses coded up just yet. Jono Slack, or somebody else with the older TriElmar -- does the EXIF show the correct focal length for each setting? Under 1.09 only or already at 1.06? thanks, scott Hi Scott, That didn't change with the firmware, it just applies to many lens codes though not all. The article is still in draft but I ended up coding the Zeiss 25 as a 28 Summicron and the coding is active with the 28/90 and 24/35 frame line positions (perhaps also the 50/75, haven't checked). Cheers, Sean Link to post Share on other sites More sharing options...
sean_reid Posted January 14, 2007 Share #6 Posted January 14, 2007 So it looks like the camera is only looking at the lever position when the lens code indicates it should. Exactly. Cheers, Sean Link to post Share on other sites More sharing options...
artur5 Posted January 14, 2007 Share #7 Posted January 14, 2007 Advertisement (gone after registration) Hi Scott, That didn't change with the firmware, it just applies to many lens codes though not all. The article is still in draft but I ended up coding the Zeiss 25 as a 28 Summicron and the coding is active with the 28/90 and 24/35 frame line positions (perhaps also the 50/75, haven't checked). Cheers, Sean Sean, did you try to code the Zeiss 25 as a Elmarit 24 ASPH ? If i'ts so, what results you got with the dif. frame positions ? Regards Arturo Link to post Share on other sites More sharing options...
scott kirkpatrick Posted January 14, 2007 Author Share #8 Posted January 14, 2007 So it looks like the camera is only looking at the lever position when the lens code indicates it should. So it will be valuable if people with the less common lenses report to this forum if their lens shows up in EXIF with any frame line setting, or only a specific one. This can get saved in Carsten's website. It may turn out that none do now. scott Link to post Share on other sites More sharing options...
ho_co Posted January 14, 2007 Share #9 Posted January 14, 2007 Calling it "the first Tri-Elmar" is misleading, since there are two versions of the same lens, and "the old Tri-Elmar" is ambiguous for the same reason. Suggestions: NOTE = Normal Tri-Elmar EATE = Earlier Tri-Elmar TEAT = Tri-Elmar Early TETE = Tele Tri-Elmar (at least partly when used on the M8) Just a thought. Would be nice to find some kind of parallel to WATE for the 16/28/21. --HC Link to post Share on other sites More sharing options...
marknorton Posted January 14, 2007 Share #10 Posted January 14, 2007 HC, I think you need to get out more... Link to post Share on other sites More sharing options...
ho_co Posted January 14, 2007 Share #11 Posted January 14, 2007 HC, I think you need to get out more... Thanks, Mark! I needed that, I guess. But gosh... What happens if Leica comes out with another tri-focal before we know what to call this one? We'd have the WATE, the FOTE (first-order TE) and the TOTE (third-order TE). So we'd have to name two lenses at once. Better do it while we've got the time, I say! And what if they redesign the WATE to make it more usable with the M8, as you've suggested? Would that be the M8TE, or the MOTE (Modernized TE)? --HC Link to post Share on other sites More sharing options...
sean_reid Posted January 15, 2007 Share #12 Posted January 15, 2007 Sean, did you try to code the Zeiss 25 as a Elmarit 24 ASPH ?If i'ts so, what results you got with the dif. frame positions ? Regards Arturo Hi Arturo, I was unable to code it as an Elm. 24 but it is doing very well coded as a 28 Summicron. The 24/25s article should be done by late next week (I hope). Cheers, Sean Link to post Share on other sites More sharing options...
