Power Switch Detent
marknorton
Just received my second M8, a couple of things to note.
First, interesting that the serial no is already over 5000 - mine is 31054xx. First one from beginning of November is 31010xx.
Second, done the usual banding test, all seems fine. Firmware is 1.09, as expected.
Most significant difference I can see is that the power switch is MUCH better. None of the slop and weak detents in the first camera, it has a much more reassuring feel about it and much more positive detents.
The shutter release is also improved, still slightly gritty but it looks like there is more resistance to the second stop which makes the release point much more positive.
I'm going to ask Leica to fix my first one which is in for upgrade.
So, one black, one chrome, difficult to say which I like better...
Hi Mark,
My M8 is "second batch" - got it last week - and my only real nit pick is that the power switch detent is a bit free. On a couple of occasions I've pressed the shutter and nothing has happened except a red blink at the top of the viewfinder! The switch has accidentally moved onto the self timer. If you notice a difference the first batch must have been really slack!
Keith, yes, in the first camera, the power switch knob moves around, now it seems much more anchored and the detents are stiffer. I could not imagine this switch moving accidentally to self-timer whereas it has happened often enough with the first camera.
My first camera may have been faulty, but I would say how it is on the new one is just perfect for the power switch and much improved for the shutter release. If they could remove that last trace of grittiness, it too would be perfect.
I've told Leica I'm more than happy to pay for current production parts to be put in my first camera.
As for black and chrome, I do feel the black camera exudes a "hewn-from-solid" feel, where the chrome camera has the classic traditional look.
My camera is in Germany (I suppose). I would like to have those things fixed.
They should do it automatically for all "first batch" cameras sent to Solms for repair !!!!!
Ruben, I sent an email to Customer Service with full details of serial numbers and so on.
If you remember the first Luminous Landscape review, Michael Reichmann mentioned this so it looks like they've made a change somewhere. I don't think it's worth having done specially but since my camera is going to be in bits, it makes sense to have them check it.
Mark, my serial number starts 3100xxx. I received this camera, from the second batch, on 12/13.
... [deleted text in between] ...
So, is this a fine art of martketing trick from Leica? Slow down the repair for the 1st batch so that the owners will buy a 2nd M8 because they can't wait? :D Looks like it worked
It's true, the use serial numbers are a mystery, it would be interesting to know whether they make a batch for the US market, then one for Japan, then one for Europe. The only country difference I can see is the safety label on the bottom. In Europe it has the waste bin icon, in the US, I assume it has the UL logo.
Maybe there's someone in Solms who delights in giving us the run-around in trying to understand how serial numbers are used.
Still, it does hint at several thousand M8s out there by now.
Arthur, no, I'd always planned to buy two, one of each! As I explained to SWMBO, "how many pairs of shoes do you have?" Case dismissed.
Mark,
I have a second-batch camera with a 31002xx serial number -- go figure. The power switch on mine has very crisp and secure detents.
Larry
The power switch and shutter on my second batch one . # 53xx (I had it wrong in an earlier post) feel rather similar to the ones on my first batch one (#11xx) So maybe it is more a question of sloppy tolerances and luck of the draw. The power switch is pretty good on both, but the shutter release does no even come close to earlier M types.
Jaap, my serial numbers are 10xx and 54xx so you may well be right it's down to luck and Leica may well tell me it's within tolerance.
As for the shutter release, it's the travel from the first pressure point to the second which I don't like, no silky gliding of PTFE coated surfaces against each other, instead gritty metal on metal.
I'm wondering if M7 owners could help us here. How is it on this camera?
Mark,
My M7's release is silky smooth, and my M8, like yours, feels gritty. I think I can live with it, though.
Larry
