The front viewfinder construction question in M3!
mintnana
I found out the loosening of the front viewfinder window glass in my M3,
when cleaning up dusts by my index finger with polisher cloth.
I was afraid of pushing too hardly and breaking the window glass.:eek:
But when another M3’s window glass was depressed by finger tip,
the glass was not so stable as I thought too.
Both are fragile and unstable to the pressure from anterior.
I’m afraid that small particles of dusts, sands, rain drops ,moisture ,
so on such a thing may intrude into the inside of the finder mechanism
from slits between the finder glass and a body frame .
Is it default ? If so ,how opposing against the foreign bodies?
I think it more stable in M3.
Another type of window (for example MP,M6,M9) is rigid ,
not occurring depression against finger pressure.
Is there anyone for same experience?
How about MP-3 just as same type of the finder as M3?:(
Thanks a lot of practical adovices in advance! :)
Guest dk_samurai
My M3 double stroke from 1957 is quite stable. I'm applying quite a bit of pressure to all three windows, but cannot see that they're giving at all.
Good luck.
/David
The front window on my M3 is also kind of loose. I noticed that when I accidentally touched it with my finger.
I am not worried about it but am cautious about not touching / pressing it.
Good luck.
/David
Thank you for the first response, David.
I really appreciate your trying to make sure it.
My M3 is also double stroke one ,No 75xxxx.
I wonder where does the difference come from ?:(
Thank you for quick reply, mmk60.
My experience is not the only one.
That makes me getting relieved about it.
I am worry about whether sending my cameras to repair survice or not.
But decided to keep them just as they are.
I must keep in mind to avoid pushing the window carelessly any more.
I made too much rough handling them all this time.:(
I wish my tinny posting will ring an alarm bell
on handling the view finder window.
Leica M is not always solid.
Your folks,
take care with your Leica M gently.:D
