Steve Ash Posted July 15, 2010 Share #1 Posted July 15, 2010 Advertisement (gone after registration) My M8.2 suddenly developed a coffee ring at the beginning this year. After the first consternation I came to the conclusion that it does not really hurt me in my shooting and that I could utilize it instead to prolong the warranty by sending the camera to Leica CS at appropriate time. Today I realized at my surprise that the coffee ring cured by itself somehow and disappeared. Has anybody seen this before or has a reasonable explanition? Moreover I am keen to know if I can take it for granted that it will not appear again. Regards Steve 2 Quote Link to post Share on other sites More sharing options...
Advertisement Posted July 15, 2010 Posted July 15, 2010 Hi Steve Ash, Take a look here Coffee ring cured by itself. I'm sure you'll find what you were looking for!
sfokevin Posted July 15, 2010 Share #2 Posted July 15, 2010 I believe that the coffee ring is caused by condensation (water) entering thru a minute crack in the LCD cover... In the beginning the condensation may disappear completely leaving no ring... But I would bet over time with successive amounts of condensation entering with dust and pollution that the dust and pollution will remain even when the condensation evaporates leaving a permanent ring 1 Quote Link to post Share on other sites More sharing options...
inalux Posted July 19, 2010 Share #3 Posted July 19, 2010 I had that coffee ring too, but it appears to dissapear if the temperature is getting warmer. Curious if it would happen again in the winter.... Quote Link to post Share on other sites More sharing options...
jaques Posted July 19, 2010 Share #4 Posted July 19, 2010 I am just about to send an M8 to solms to have the screen replaced for the same reason... it would be kind of embarrassing if the ring were to disappear in transit... BTW my M8 has been modified with new leather and also has had the M8 engraving removed- I have heard that Solms sometimes repair such things as a matter of course- is something like this likely to happen- or even possible? Be great if they replaced the top plate- it is a little worn... also does anyone have any idea a repair like this takes? Quote Link to post Share on other sites More sharing options...
inalux Posted July 19, 2010 Share #5 Posted July 19, 2010 maybe this is the new firmware update with the self healing technology Quote Link to post Share on other sites More sharing options...
hoppyman Posted July 19, 2010 Share #6 Posted July 19, 2010 Jaques rather than guess what might happen, it might be better to speak with CS first, either by email or telephone. Let them know what you want or ask as many questions as you like. Your covering would have to be removed for disassembly so you should establish what you want to happen there. Very likely it would not be able to be re-fitted without damage at least. A replacement top plate would not be cheap. If it is worn or modified that would not be a warranty issue. It is not unknown for Leica Camera to perform additional work for people without always charging for it, but when you have custom modifications involved it gets more complicated. I am just about to send an M8 to solms to have the screen replaced for the same reason... it would be kind of embarrassing if the ring were to disappear in transit... BTW my M8 has been modified with new leather and also has had the M8 engraving removed- I have heard that Solms sometimes repair such things as a matter of course- is something like this likely to happen- or even possible? Be great if they replaced the top plate- it is a little worn... also does anyone have any idea a repair like this takes? Quote Link to post Share on other sites More sharing options...
AndrejK Posted December 7, 2010 Share #7 Posted December 7, 2010 Advertisement (gone after registration) I have sent my M8 to Solms for repair of the coffee-ring problem under warranty. They were very nice and polite before I sent the camera in and they returned it repaired - sort of. I can no longer see the coffee ring on the display, but it seems the display was not replaced! The repair documents only mention general check and cleaning of the camera, no replacement parts. But most importantly - my own protecting screen cover foil is still there on the display! So I am pretty sure the display was not changed, yet the problem vanished somehow:-) Andrej Quote Link to post Share on other sites More sharing options...
Scott Root Posted December 8, 2010 Share #8 Posted December 8, 2010 Can a person get a M8 or M9 top plate without the M8 or M9 engraving? Scott I am just about to send an M8 to solms to have the screen replaced for the same reason... it would be kind of embarrassing if the ring were to disappear in transit... BTW my M8 has been modified with new leather and also has had the M8 engraving removed- I have heard that Solms sometimes repair such things as a matter of course- is something like this likely to happen- or even possible? Be great if they replaced the top plate- it is a little worn... also does anyone have any idea a repair like this takes? Quote Link to post Share on other sites More sharing options...
jaapv Posted December 8, 2010 Share #9 Posted December 8, 2010 I am just about to send an M8 to solms to have the screen replaced for the same reason... it would be kind of embarrassing if the ring were to disappear in transit... BTW my M8 has been modified with new leather and also has had the M8 engraving removed- I have heard that Solms sometimes repair such things as a matter of course- is something like this likely to happen- or even possible? Be great if they replaced the top plate- it is a little worn... also does anyone have any idea a repair like this takes? The leather will be lost if the camera has to be opened and if you don't tell them to leave it they will repaint the M8 engraving. However, sometimes Leica will ask you whether you want Vulcanite instead of the standard covering if there is special leather on the camera. Quote Link to post Share on other sites More sharing options...
Mikael Siirilä Posted December 20, 2010 Share #10 Posted December 20, 2010 Great to hear an explanation. Its been very cold here in Finland and I carry my M8.2 always with me. Now I have a "coffee ring" nearly half the LCD size. Pretty sure its condensed moisture... perhaps something like Newton rings between the LCD and the saphire. Quote Link to post Share on other sites More sharing options...
santdtman Posted December 21, 2010 Share #11 Posted December 21, 2010 Anyone tried to dry it with silica gel? Quote Link to post Share on other sites More sharing options...
