Malcolm--
Just to add the obvious to what Eoin said: If you wear corrective lenses while using the camera, then you don't need to worry. That is, if you can see the contents of the viewfinder sharply (with or without glasses), then you're fine.
If you can't see the VF sharply, that means that the camera's correction doesn't match your eye, and you need to get correction either for the finder or for your eye.
I believe that the -0.5 dpt correction is standard with all manufacturers' current eye-level-design cameras. (Leicaflex models had -1.0 dpt: one of the well-considered quirks of the German-made Leica reflex cameras that changed when they enlisted Minolta's aid with the R3.)
I think -0.5 dpt means that the optical system projects the image to 0.5 meter distance; -1.0 dpt means that the image is projected to 1.0 meter distance.
--HC
