bradhusick Posted December 25, 2006 Share #1 Â Posted December 25, 2006 Advertisement (gone after registration) Dear fellow enthusiasts, enclosed are some M8 noise profiles for use with Noise Ninja. These were created using a new 1.09 M8, tungsten light, photographing an RGB color target. It is likely that these are not optimized for other lighting conditions, but tungsten represents a more challenging noise environment for the M8 so that's where I started. Â To use them, download the files and rename the extension from .TXT to .NZP and put them in your Noise Ninja profiles folder. (This forum does not allow uploads of .nzp files). Â As always, it's up to you how much noise reduction to do, so play with the settings until you reach a compromise you like. Â -Brad m8_160_tungsten.txt m8_320_tungsten.txt m8_640_tungsten.txt m8_1250_tungsten.txt m8_2500_tungsten.txt Link to post Share on other sites More sharing options...
farnz Posted December 26, 2006 Share #2 Â Posted December 26, 2006 Thanks, Brad, I'm keen to try them out. Â Got to wait for my M8 to arrive first of course! (Feb/March according to my dealer. But by then I may have gone crazy from the wait and stormed into the nearest mall and shot everyone in sight with my D2!) Link to post Share on other sites More sharing options...
ho_co Posted December 27, 2006 Share #3 Â Posted December 27, 2006 Same here, Brad. Downloading and filing these will give me something to do while awaiting my M8 as well! Â Thanks for taking the time to post them. Â --HC Link to post Share on other sites More sharing options...
jobe Posted December 27, 2006 Share #4 Â Posted December 27, 2006 Thank you very much for posting these , Brad. Link to post Share on other sites More sharing options...
bradhusick Posted December 27, 2006 Author Share #5 Â Posted December 27, 2006 You're welcome, folks. I would be happy to create and post other Noise Ninja profiles you think would be useful, such as 5000K lighting. Â -Brad Link to post Share on other sites More sharing options...
Peter41951 Posted December 27, 2006 Share #6 Â Posted December 27, 2006 Brad, many thanks for posting these. Â If anyone has a problem renaming file name extensions, as I had, this will be useful: Â FAQ - How do you rename the extension of a file in Win2K/XP? Link to post Share on other sites More sharing options...
khanosu Posted December 27, 2006 Share #7 Â Posted December 27, 2006 Advertisement (gone after registration) Thanks Brad! This is very useful. Â By the way did you use any IR cut filters for these profiles? I am wondering how much effect an IR cut filter will have on these profiles. Â Thanks! Â Furrukh Link to post Share on other sites More sharing options...
bradhusick Posted December 27, 2006 Author Share #8 Â Posted December 27, 2006 No, I used no filters. The lens was a new Zeiss 50mm f1.5. Link to post Share on other sites More sharing options...
wlaidlaw Posted February 11, 2007 Share #9  Posted February 11, 2007 You're welcome, folks. I would be happy to create and post other Noise Ninja profiles you think would be useful, such as 5000K lighting.  -Brad  Brad,  I regret I cannot get these to load into NN used as a plug in on PSE4 for Mac. After renaming them as NZP files on my desktop, they stay greyed out when I browse for the files to install them. I tried dragging them directly into where other NN profiles are stored and loading but still no luck. I have previously had no trouble loading profiles for my Sony DSC-R1. Any thoughts?  Wilson Link to post Share on other sites More sharing options...
bradhusick Posted February 12, 2007 Author Share #10 Â Posted February 12, 2007 Wilson, Make sure they end up being named something like m8_2500_tungsten.nzp and then drag the file into the Plug-Ins/NoiseProfiles folder of Photoshop. Â Other than that, I am not sure what would cause this. -Brad Link to post Share on other sites More sharing options...
wlaidlaw Posted February 12, 2007 Share #11 Â Posted February 12, 2007 Brad, I now know what the problem is but not the solution. When you rename the profiles in Finder (the Mac equivalent of Windows Explorer), the .txt suffix is retained as a hidden attribute. It is not visible in Finder but when you drag the profile into another programme e.g. as an attached file to an email, the second suffix appears so that the profile looks like m8_2500_tungsten.nzp.txt It is therefore hardly surprising they will not install. I have tried everything I can think of to get rid of the second suffix but with no luck. I have emailed Picturecode to ask if they have any ideas. Â Wilson Link to post Share on other sites More sharing options...
wlaidlaw Posted February 12, 2007 Share #12  Posted February 12, 2007 Wilson,Make sure they end up being named something like m8_2500_tungsten.nzp and then drag the file into the Plug-Ins/NoiseProfiles folder of Photoshop.  Other than that, I am not sure what would cause this. -Brad  Brad,  I have done it - Phew! I will explain how as it may help other Mac users. I stoked up the boiler on an old Windows computer, transferred over your .txt profiles on a memory stick, then renamed them to .nzp files in the command window using MS/DOS - that got my memory working remembering how to do that. I then reloaded the renamed files to the memory stick and loaded the profiles from that into one of my Macs - success. Many thanks.  Wilson Link to post Share on other sites More sharing options...
SnapperJ Posted February 13, 2007 Share #13  Posted February 13, 2007 You're welcome, folks. I would be happy to create and post other Noise Ninja profiles you think would be useful, such as 5000K lighting.  -Brad  Those would be very useful, many thanks. Link to post Share on other sites More sharing options...
wstotler Posted February 13, 2007 Share #14  Posted February 13, 2007 Brad, I have done it - Phew! I will explain how as it may help other Mac users. I stoked up the boiler on an old Windows computer, transferred over your .txt profiles on a memory stick, then renamed them to .nzp files in the command window using MS/DOS - that got my memory working remembering how to do that. I then reloaded the renamed files to the memory stick and loaded the profiles from that into one of my Macs - success. Many thanks.  Wilson   Wow! Looks like a feature in your case wasn't. . . . (The hiding of extensions in OS X is a feature, but can cause confusion when working with files.) In OS X all you need to do is go to Finder and change a preference. Go to the Finder. Select Finder --> Preferences --> Advanced. And check the "Show all file extensions" checkbox. Then you can see extensions in the filenames and edit them to your heart's content. In my opinion it's a good idea to always leave this box checked so you can see full filenames. See screenshot. Cheers. --Will Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/12065-noise-ninja-profiles-for-m8/?do=findComment&comment=170533'>More sharing options...
wlaidlaw Posted February 13, 2007 Share #15  Posted February 13, 2007 Wow! Looks like a feature in your case wasn't. . . . (The hiding of extensions in OS X is a feature, but can cause confusion when working with files.) In OS X all you need to do is go to Finder and change a preference. Go to the Finder. Select Finder --> Preferences --> Advanced. And check the "Show all file extensions" checkbox. Then you can see extensions in the filenames and edit them to your heart's content. In my opinion it's a good idea to always leave this box checked so you can see full filenames. See screenshot. Cheers. --Will  Will,  Thanks for that tip it will be very useful. Have just gone and reset all 4 Macs. The coal smoke from my windoze machine was making me cough anyway ;-}}  Wilson Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/12065-noise-ninja-profiles-for-m8/?do=findComment&comment=170566'>More sharing options...
bradhusick Posted February 13, 2007 Author Share #16 Â Posted February 13, 2007 Folks, Here are a set of profiles for the M8 under 5000K lighting. These were produced with a 50mm Summilux ASPH with no filters. Please follow the original steps for renaming, etc. and place them in the same folder as last time. Â -Brad m8_iso160_5000k.txt m8_iso320_5000k.txt m8_iso640_5000k.txt m8_iso1250_5000k.txt m8_iso2500_5000k.txt Link to post Share on other sites More sharing options...
SnapperJ Posted February 14, 2007 Share #17  Posted February 14, 2007 Folks,Here are a set of profiles for the M8 under 5000K lighting. These were produced with a 50mm Summilux ASPH with no filters. Please follow the original steps for renaming, etc. and place them in the same folder as last time.  -Brad  Many thanks. Link to post Share on other sites More sharing options...
bnelson Posted February 14, 2007 Share #18 Â Posted February 14, 2007 Brad, Â Many thanks for that Mac tip. Great idea. Â Bill Link to post Share on other sites More sharing options...
