Simon:
I think it is just related to the qualities of the lenses. Few super wides are sharp at the edges wide open. The exception might be the 19mm ROM on the the DMR, but you need to have a good copy.
What other wides are you having problems with? If you are shooting Leica wides, you can look up the MTF curve on the Leica web site. I think I once calculated that 15mm-16mm on the MTF curve is the edge of the sensor. If the graph take a big dip before 15mm, the lens will not perform as well on the edges of the frame.
Robert
