boilerdoc Posted December 14, 2006 Share #1 Posted December 14, 2006 Advertisement (gone after registration) I have a used Bellows II. I also have an M7 - which this bellows won't fit onto!!! Grr....!!! Which of the M models will accept these bellows and still have TTL flash?...or at least TTL exposure? Will the M6TTL work? Thanks. steve Quote Link to post Share on other sites More sharing options...
Advertisement Posted December 14, 2006 Posted December 14, 2006 Hi boilerdoc, Take a look here Bellows question. I'm sure you'll find what you were looking for!
leicapfile Posted December 15, 2006 Share #2 Posted December 15, 2006 Steve, The bellows (either I or II) will not attach directly to the camera body. You must use a Visoflex (in this case of a Bellows II, either a Visoflex II, IIa, or III) between the Bellows II and the camera body. When properly set up with the Visoflex, any of the TTL M's should readily work with either auto exposure w/o flash, or TTL flash exposure Jerry Quote Link to post Share on other sites More sharing options...
Michael Hiles Posted December 16, 2006 Share #3 Posted December 16, 2006 Steve, It is worth noting that only the Visoflex III will fit onto the M7. The II and IIa will work on the MP and earlier shorter cameras. Quote Link to post Share on other sites More sharing options...
