jimbo035 Posted November 28, 2009 Share #1 Â Posted November 28, 2009 Advertisement (gone after registration) Saw a small more-or-less elliptical chip whilst looking through the rear element of a recently acquired 21mm Super-Angulon-R today and further investigation with a 8x magnifying glass revealed it to be on the surface of the front element, about halfway between the centre & the edge. Taking the magnification factor into account, the chip is less than a milimetre in diameter, and certainly difficult to find looking at the front of the lens with the naked eye under a bright lamp (in my case assisted by newly prescribed bi-focal eye-glasses) Â The (TMax 400) film with several frames taken wth the Angulon just after it arrived is being sent off for D&P Monday, and I'm hoping the damage won't have affected the images. Â Anyone out there happily using a lens that has suffered similar damage ? Am I right in thinking its too insignificant to worry about, or should I send the lens back for a replacement ? Luckily the Vendor has another two in stock..... Link to post Share on other sites More sharing options...
Advertisement Posted November 28, 2009 Posted November 28, 2009 Hi jimbo035, Take a look here Lens front surface chipped - how worrying ?. I'm sure you'll find what you were looking for!
wildlightphoto Posted November 29, 2009 Share #2 Â Posted November 29, 2009 Saw a small more-or-less elliptical chip whilst looking through the rear element of a recently acquired 21mm Super-Angulon-R today and further investigation with a 8x magnifying glass revealed it to be on the surface of the front element, about halfway between the centre & the edge. Taking the magnification factor into account, the chip is less than a milimetre in diameter, and certainly difficult to find looking at the front of the lens with the naked eye under a bright lamp (in my case assisted by newly prescribed bi-focal eye-glasses)Â The (TMax 400) film with several frames taken wth the Angulon just after it arrived is being sent off for D&P Monday, and I'm hoping the damage won't have affected the images. Â Anyone out there happily using a lens that has suffered similar damage ? Am I right in thinking its too insignificant to worry about, or should I send the lens back for a replacement ? Luckily the Vendor has another two in stock..... Â Theoretically it will affect the image in some way, whether perceptible or not is another question. There photos were made with a 560mm f/6.8 Telyt with several scratches and nicks visible with the naked eye: Â Â Â Â I wouldn't worry about it but if you have nagging doubts, send it back. Or ask for a price adjustment. Link to post Share on other sites More sharing options...
Guest AgXlove Posted November 29, 2009 Share #3 Â Posted November 29, 2009 Anyone out there happily using a lens that has suffered similar damage ? Am I right in thinking its too insignificant to worry about, or should I send the lens back for a replacement ? Luckily the Vendor has another two in stock..... As I understand such matters, the damage will likely not show up in your negatives/chromes unless you are shooting directly into a harsh light source or unless direct light is striking the front element of your lens. In such a scenario, the chip could cause flare or reflections inside the lens. Â If the vendor has two more to choose from, I'd exchange it, if doing so would get you a better quality lens. Link to post Share on other sites More sharing options...
earleygallery Posted November 29, 2009 Share #4 Â Posted November 29, 2009 I'd be surprised if such a small defect would show up at all, see how the negs turn out. Â I have a Nikkor 28mm which I really shouldn't have bought, even if it was cheap, it's pretty badly marked on the front element but the photos with it look fine. My father used a Retina lllc which had a cracked front element albeit near the edge, again never caused any issues. Â Whether to replace or not is a tough one - if you can swap for an identical lens in as good condition but without the chip then I'd do it, but if say your lens if perfectly good otherwise and another lens has cleaning marks or more internal dust I'd stick with the chipped one! Link to post Share on other sites More sharing options...
pgk Posted November 29, 2009 Share #5 Â Posted November 29, 2009 I would say that the effect of a small chip on the front surface of the front element on performance is unlikely to be visible under normal circumstances but it may increase flare if shooting into the light. A simple remedy if you decide to keep it and if you are prepared to do so, is to use a black felt tip pen to blacken the chip - then it won't create additional flare . Many years ago I owned a 135mm Takumar lens with a bad chip which did cause flare - blacking the chip solved this, but it was a cheap lens and this was because of the chip which had seriously devalued it before I bought it. If you can get an unchipped one instead it may well be worth doing so depending on the price you paid. Link to post Share on other sites More sharing options...
Guest mc_k Posted November 29, 2009 Share #6 Â Posted November 29, 2009 probably affect your resale value, though Link to post Share on other sites More sharing options...
jimbo035 Posted November 29, 2009 Author Share #7 Â Posted November 29, 2009 Advertisement (gone after registration) probably affect your resale value, though my resale value ? Oh, you're thinking that there may be a day when I want or need to sell the Angulon. Â Very very unlikely, as I'm perfectly happy to keep on using the SL and three lenses I've bought indefinately, apart from the 1966 35/2.8 - perhaps soon to be part-exchaged for a "younger" 35 Summicron. Link to post Share on other sites More sharing options...
marcg Posted November 29, 2009 Share #8 Â Posted November 29, 2009 Yes, but your heirs may want to sell it. Link to post Share on other sites More sharing options...
tobey bilek Posted November 29, 2009 Share #9 Â Posted November 29, 2009 I thinks marcg has the implications properly addressed. Or if you want to sell it. Â If it was cheap, keep it. If not as advertised, return it. Â If you keep it and want to eliminate possible problems, then touch up the depression with india ink and a ooo brush. the classic fix, You will never see it on film. Link to post Share on other sites More sharing options...
jimbo035 Posted November 30, 2009 Author Share #10 Â Posted November 30, 2009 A satisfactory conclusion, as the vendor is willing to take it back and to hold one of the other two they have in stock accordingly. Link to post Share on other sites More sharing options...
integrale Posted November 30, 2009 Share #11 Â Posted November 30, 2009 Some time ago I found on the internet a (non-scientific) test on the impact on IQ of dust, scratches and damage to the lens. Â I'm sorry but I can't locate the test right now (will post link, if/when I locate it); the results were quite surprising that even heavy grease and scratches had a limited impact on image quality. Â Of course, it depends on placement of the scratch, how much light is de/reflected passing through the element. Â You can try some googling (I will). Link to post Share on other sites More sharing options...
gabriel Posted December 1, 2009 Share #12 Â Posted December 1, 2009 Lets have a competition to see who has the biggest chip (on their lens) Link to post Share on other sites More sharing options...
wildlightphoto Posted December 2, 2009 Share #13  Posted December 2, 2009 Lets have a competition to see who has the biggest chip (on their lens)  Or see how much virtual anguish we can cause with photos of our chipped glass  I've had my worst one repaired: a fingernail-sized flake off the edge of the 280 APO's front element. Five years ago. Still hurts to think about it. Link to post Share on other sites More sharing options...
dkCambridgeshire Posted December 3, 2009 Share #14  Posted December 3, 2009 I have a 90mm Summicron M Aspheric with a chip in the front element which I bought used at a good discount. The chip is just off centre and so far has had no effect on the image. If it ever does affect the image eg when used against the light then I'm confident that a spec. of black paint will remedy the problem.  Cheers  dunk Link to post Share on other sites More sharing options...
gwelland Posted December 3, 2009 Share #15 Â Posted December 3, 2009 The biggest issue with an front element damage is the subsequent sensitivity to flare/artifacts in direct light. I've had a similar situation with a lens with very minor damage that 99.9% of the time is perfect but when catching the light of say direct view into the sun or a street light it will produce an ugly flare. Link to post Share on other sites More sharing options...
