Showing results for tags 'what to choose'.
When I joined this forum a couple of months ago I had just bought the M9 with the 50mm Cron. Since then you have helped me with buying the 21mm Elmar f2.8 and the Tele-Elmarit 90mm f2.8. I felt as well that I needed something in between the 50 and 21 and last week being in Hong Kong I bought a new 28mm Cron. It has been a great lens during the weekend to shoot especially the street markets. And architecture as well (I wonder how much I will use the 21mm from now on). I feel I have all the lenses I need. The next thing will be to upgrade the 50mm and then the 90mm. Both to something with larger maximum aperture. 50mm upgrade will come first. I am thinking mainly on the Noctilux. I have tried the 0.95 a couple of times and I like it very much. But the price is very high and would like to know if I should consider earlier Noctilux lenses and in that case which ones? There might be older ones that gives "better" looks? I see they are quite common on the second hand market. (Summilux can also be an option). Thank you.
Dear L-forum, I have a great opportunity to buy a Noctilux lens but no opportunity to test it or compare it. I have just tested the new 0.95 and I like it. It is the version 2 below that has been offered to me: Version 1 = 50mm F1.2 Noctilux Version 2 = 50mm F1.0 E58 Noctilux (removable pin hood) Version 3 = 50mm F1.0 E60 Noctilux (removable hood) Version 4 = 50mm F1.0 E60 Noctilux (built in hood) Does any one of you have experiences about the lens? Did you have some issues with it? I have read a little about focus shift but is it a real problem if I only shoot wide open 98% of the time? It is a lens from 1977 and goes for the same price as a Summilux 1.4. Thank you!
I have got great help here before, both when buying my 21mm and 90mm and now I am here again. And I have one 50mm Cron additional to that. Now I am thinking of a 35mm as well. Which one should I get? Or would you have put priority on another lens than the 35mm? I want to get a Leica lens and I have been looking on the new ones out there in the shops but maybe this time it would have been nice with a really old one. I am shooting with a M9.
