Showing results for tags 'shutter problem'.
ATTN: M10R Black Paint Owners We should try to find out if this issue is common in the forum. Responses are all over the place so here we can have one place we can see Yes and No. Take a second to respond and thanks in advance TAKE THE SURVEY
- 4 replies
- shutter problem
- m10-r
(and 1 more)
Tagged with:
When I use a one-thousandth shutter, these nasty black line marks will appear in the same position in picture. Is the problem of high-speed shutter ? Can it be solved by adjusting the shutter curtain tension? The film has been checked, it is not a problem with processing and scanning.
Hi all, Just received my first R3 MOT electronic yesterday. The camera turns on, the automatic function seems to work, the light meter is functioning, but when the camera needs to work at shutter speeds lower than or equal to 1/8s the camera mirror stays up and the camera remains open including the curtain. Everything gets stuck until I remove the battery and advance the film advance lever. How can I fix this problem step by step? Do I need to clean the electromagnet? Is this an easy fix or not? Thanks!
- 11 replies
- Mirror stuck
- r3
(and 2 more)
Tagged with:
