Showing results for tags 'shoulder stocks'.
I have quite a few Telyt 400mm and 560mm lenses and they come with different shoulder stocks. The stock on the left has a flat platform with two pins to attach to the bottom of a pistol grip which has two holes (in addition to the screw hole). The stock in the middle has a pistol grip which accepts a trigger cable. The "C" shape shoulder butt has two holes for attachment to the stock at different positions, and two more holes further out at both ends with a flat cut-out which does not look like for stock attachment. I don't know what those are for. The stock on the right has a similar pistol grip head with the addition of a thumb screw to secure the trigger cable, but the stock itself is quite different in design that the butt plate can be removed and attached to the bottom of the pistol grip to turn it into a small table pod. I am wondering if these different designs were from whatever time periods, or if they are specifically for whichever Telyt lenses (the f/6.8 series or the f/5.6 series)?
- 11 replies
- 2
