Showing results for tags 'ltm bayonet'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 3 results
  1. Hey guys, I'm currently setting up a Leica Screw Mount kit. I will be buying a CLA'd Leica iii with a new splitbeam mirror. The whole kit is planned to be used for a gap year in New Zealand and therefore it needs to be small but still affordable because I'm still a student. Now I can't decide between a probably uncoated but CLA'd Ltm 5cm Elmar f/3,5 and a Nikkor 5cm f/2. The Elmar is incredible small which is amazing for travalling while still having a good quality as a like. And it fits in the ever ready case. BUT I really like using filters and it is very hard to use them on the Elmar because it needs those special A36 filters and I need to put them off everytime to change the aperture which is still hard without the filter. The latter on the other hand doesn't have the advantage of being able to be pushed inside the body to become very small but it uses normal filters and it isnt hard to set the aperture with it. But it does not fit in the everready bag (or am I wrong?). The question is now which one is better? How about the optical quality, I have no ressources to exactly compare them. Greetings
  2. Hello. I've recently sold my m240, and will purchase either the m10p or the m10r in the next couple of weeks. Regarding the m10r: My understanding is that older lenses, like my 50mm Canon Sonnar f/1,5 LTM, will deliver poor results, as they are unable to resolve the 40mp resolution. This was also mentioned in a video episode on Red Dot Forum. Does anyone have any real world experience with this? Thank you.
  3. Servus,, letztes Jahr bin ich durch eine Reinvestion (Scotch) und habe den Schritt zu Leica gemacht bzw vor zwei Jahren hatte ich ja schon das R-System besessen jedoch alles wieder verkauft und auch mit in die M gespielt und verliebt. Aber da mir es keine Ruhe gelassen hat war ich dann auf Suche nach alten Schätzchen und somit haben sich drei Barnacks der IIf/IIIf/IIIC den Weg zu mir gefunden auch zwei M3 DS/SS und sind nun Abwechslungsreich mit auf meinen Touren auch im Job. Quasi als EDC😁 Die ersten Filme sind belichtet wobei bei zwei'n die längeren Zeiten nicht gepasst haben also den Verkäufer angeschrieben und ohne Probleme wurden neu justiert. Und bei der IIIf war Lichteinfall somit auch angeschrieben und wurde auch ohne Probleme seinerseits erneuert. Entschleunigt unterwegs zu sein macht schon was her und einfach der Spaßeffekt zielt schon ab.
