Showing results for tags 'lens hood'.
Hi, is there a way to remove the lens hood from the 250mm telyt R f4 lens? it keeps sliding down, so id rather remove it as i don't like hoods anyway its this model: https://www.l-camera-forum.com/leica-wiki.en/index.php/250mm_f/4_Telyt-R_I
Hey everyone. I recently got my hands on a summicron 50mm v4 that comes with a 12585 hood. Fantastic lens by the way. But I’m having trouble to use a 39mm thread filter together with the hood. When the filter is threaded on the lens, the hood simply cannot go all the way in, because the filter is blocking the thin edge in the middle of the lens hood, which is narrower than the size of the filter. Does anyone have experience using the 12585 hood with filters? Which ones will work with it? I’m using filters for protection of the glass. thanks! Frank
Hi, I've got the cron 35mm f/2 ASPH, the new version. I got the square black lens hood that came along with it in the box. However, I would love to get a silver one instead just like the Summilux got. I have no idea if it exists or not since I haven't found a place to buy one, but I've seen photos of the lens with a silver square lens hood. Are they real or just mockup photos? Also on Leicas own site: IF it exists, where can I order it?
Did Leica ever make a case for the FISON and in particular one that would attach to the camera strap as my Leica case only has the front of the case that would take a collapsable Elmar so would be handy to have a case on the strap, thanks.
I picked up this Hoage square hood off Amazon. I was concerned with the fit because the description said for the Q3 43 but I figured for the price, I'd try it and if it didn't fit I could return it. The hood does fit and there's no issue with vignetting or with the macro setting. It threaded in just fine. So, if you're like me and prefer the square hood but also like the brassy bronze look, the Hoage may be ideal for you, too.
Hi, I have a 11673 lens paired with a 12470 lens hood. I really love the short and lightweight hood on the 11699. I thought since they are both 35 F2 lenses, maybe they could share the same hood? So I bought a new hood and realized that wasn’t the case. Fortunately, the hood for the 11699 is larger than the 11673 lens. I’m considering drawing up a 3D model and having a CNC factory make an adapter ring. The problem is, I can hardly find the thread specifications for the lens hood in any of the Leica manuals. Does anyone happen to know the thread specifications for this hood? Let me know if you need further adjustments! Thank you
