Showing results for tags 'infrared filters'.
If someone would have Leitz price lists of 1933, I would like to know when the IR filter FIKYB appeared for the first time. In English price lists that would be March 1933. So I am curious if also German (and perhaps other language) price lists mention the infrared filter at that moment. Lex
- 4 replies
- infrared
- infrared-photography
(and 1 more)
Tagged with:
I wanted to see how well (or poorly) my TL2 could be coaxed into producing infrared or near-infrared photographs. So I started this informational topic to pass along some of what I found out. I used infrared film only very occasionally during my predominantly film days, but there were times when it was just the ticket. One of my favorite B&W films was and still is Ilford's near-infrared SFX-200 processed in PMK Pyro, both for normal and occasionally for near-infrared photos (but that's another story). It turns out that the TL2's sensor collects an impressive amount of infrared light. (Simple test: try viewing the business end of an IR TV remote through the camera. If you can see the IR diode--I assume it's a diode--light up when pressed, then you've got something to work with.) The TL2 shows the diode very well. So did the X2, but the X2 didn't fare nearly so well once I tried using it with IR filters. The exposure times were way too long. Getting the TL2 converted to Infrared is an option, and one that will preserve exposure times we are more used to. Filters, as you all know, slow exposure times down. But if you only use IR occasionally, as I do, IR conversion of the camera isn't a desirable option. So I experimented with filters, and the results are as follows: I used three filters on the TL2 in various types of scenes. The three filters were--in order of ascending visible light filtration--first, the B+W 092 (which Schneider says "...blocks visible light up to 650 nm, and at just below 700 nm it allows 50% to pass through .... From from 730nm to 2,000 nm the transmittance is very high at over 90%"). The second (perhaps the Goldilocks filter) was the HOYA R72 Infrared, which is designed to pass 95% of the light between 760nm and 860nm. The third, and darkest, filter was the B+W 093 which . . . well, I'll let them tell it: "blocks the entire visible light spectrum. It therefore appears black and in contrast to the B+W 092 infrared filter 695, it enables shots in pure infrared without the visible red. The transmittance does not exceed 1% until 800nm, but increases to 88% at 900nm." I'll put results in subsequent posts.
- 24 replies
- infrared
- infrared filters
(and 1 more)
Tagged with:
