Showing results for tags 'capture assistants'.
More search options
    • Leica Q / Leica Q2
    • LHSA Member Forum
Name
PLZ
Found 1 result
  1. Hey gang - wondering if anyone else out there is having the same issue I am presently facing in trying to enable some camera's capture assistance features on my Leica CL? I'm presently using Camera Firmware Version 2.2. Here's the items within the Capture Assistants section of the menu and a rundown of the functionality I 'have/don't have' for each: Grid Setup - Working, no issues here. Clipping - Does not display. Horizon - Does not display (this is the function that I'd really like to enable) Histogram - Does not display. Troubleshooting so far: Disabled then Enabled (and vice-versa) for each function. No dice, doesn't make a difference for the display of Clipping, Horizon, or Histogram. Only the Grid Setup functions as it should. I've looked for items elsewhere in the menu that might correspond to the functions that I can't get to work. Maybe something is cancelling out their functionality? Can't see anything though that might be the culprit? Is anyone else out there having this problem? This has only arisen after I updated to the most recent firmware (2.2). I can't quite remember though if the missing horizon/level gauge immediately went away directly after the firmware's installation.
