Showing results for tags 'bounce flash'.
Found 1 result
  1. I am scratching my head for nearly two houres now, here is the problem: I am using the SF-58 on M9. TTL works fine, but there is a problem with Auto Mode and bounce flash. In Auto Mode I am supposed to set the aperture manually on lens and flash (ISO info from camera). Here is what happens: Set aperture to f2.8 on lens and flash > exposure fine. Set aperture to f8 on lens and flash > exposure 3 stops underexposed (as if flash is still set to f2.8) I put the flash head to rest position, then back to bounce position > exposure is fine! Same thing the other way around, then with overexposure issue. Is this normal? I don't understand this behavior. I tried several times, always with the same result. Is the flash supposed to be in rest position to change its output via its aperture setting? Thank you very much!
