Showing results for tags 'battery charge'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 2 results
  1. I just added the Leica grip, and two days later, the Q3 battery is drained. I recharge it, the scenario repeats. I remove the grip, repeat the process. The battery holds the charge normally. I added a thin PVC pad between the camera contacts and the grip base. No more issues, but no more wireless charging! Is there a solution to restore normal 100% Leica device functionality?
  2. I searched the forum but did not find any information on the topic of battery damage caused by dropping, so here is my dilemma: Today I accidentally dropped one of my Q2 batteries (#BP-SCL4). It fell about 4 ft. (1.2 m) and landed on a hardwood floor. It was in a Tenba battery pouch, which has thin neoprene padding on the bottom and sides but none on the top. It sounded like it hit on the top where there is no padding (why, yes - of course!) 🙄 I see no physical damage to the battery - no dings or cracks in the outer case, and no leaking (so far). I inserted the battery into the Q2 and the camera indicates a full charge. My concern is that this drop may shorten the life of the battery, that it may not hold a charge or it may not take a full charge down the road. If anyone has had a similar experience with a Q2 or other M camera battery and can shed some light on what I can expect, it would be a great help. Thanks in advance!
