Showing results for tags 'barnack challenge #30'.
As requested by christoph_D, I have set out here the new Barnack Challenge #30, as it is his honour to set the Challenge because he was the most recent previous winner. Message from Christoph: As the winner of the last round (The Gap of Time / Die Kluft der Zeit) it is my great pleasure to set the theme for the next Barnack Challenge. So for the Barnack Challenge #30 I have chosen the theme "Autoportrait" The dates are: Taking pictures: June 25th to July 10th Posting pictures: July11th to July 24th Voting: July 25th to August 7th Good luck all! Regards, Christoph As a reminder here the rules: The Barnack Challenge runs four times a year. It is open to all Leica User Forum members. In order to participate you must shoot a roll of film in line with a predefined theme within a defined period using a Screwmount or early fixed-lens Leica. You may use any lens, regardless of age or manufacturer, as long as it is LTM. Select your shot that in your view best matches the theme and post it onto a single thread set up for the purpose by the organiser in the Barnack Challenge Sub Forum. Post-processing of your image should be kept to a minimum - nothing that couldn't be done in a wet darkroom fifty years ago. You may post your image any size within forum rules. The thread will be open for postings but NOT for voting to allow all entries to be posted before voting starts. Your entries are not anonymous; feel free to post camera, lens and film details. Voting will then be opened. Votes may then be cast on the following basis: Three points for best, two points for second and one point for third. Voting runs for two weeks. One vote per member, no voting for your own image. The winner gets the right to set the theme for the next Barnack Challenge. Als der Gewinner der letzten Barnack Challenge, (The Gap of Time / Die Kluft der Zeit) moechte ich hiermit das Thema fuer die naechste Challenge bekanntgeben: "Autoportrait" (Selbstportrait). Die Daten: Zeit zum Photographieren: 25 Juni bis 10 Juli Hochladen des Beitrags: 11 Juli bis 24 Juli Abstimmung: 25 July bis 7 August Viel Spass und Erfolg! Gruss Christoph Zur Erinnerung hier nochmal die Regeln: Die Barnack Challenge findet vier mal im Jahr statt. Jedes Leica User Forum Mitglied ist Teilnahmeberechtigt. Zur Teilnahme muessen Sie einen Film belichten, wobei die Photos dem gestellten Thema entsprechen sollten und innerhalb der angegebenen Zeit enstanden sein muessen. Die Photos muessen mit einer Schraubleica oder einer fruehen Leica mit fest eingebautem Objektive entstanden sein. Alle Objektive mit Schraubanschluss unabhaengig vom Alter oder Hersteller koennen verwendet werden. Waehlen Sie das Photo das Ihrer Meinung nach am besten dem gestellten Thema entspricht und stellen Sie es in den entsprechenden Thread im Barnack Challenge Subforum. Die Bilder sollten nur minimal am Computer manipuliert werden (Post-processing) - nur solche Manipulationen sind zugestanden die auch in einer Dunkelkammer vor 50 Jahren moeglich waren. Sie koennen Ihr Photo in jeder den Forumsregeln entsprechenden Groesse einstellen. Das Abstimmen beginnt nachdem alle Beitraege in einem gegebenen Zeitraum eingestellt sind. Ihre Bilder sind nicht anonym, und sie koennen gerne den Kameratyp, das verwendete Objektiv und Film details angeben. Nachdem der Zeitraum zum hochladen der Bilder abgelaufen ist beginnt die Abstimmung. Jedes Forumsmitglied das abstimmt muss drei Punkte verteilen: Drei Punkte fuer das beste Bild Zwei Punkte fuer das zweitbeste Bild Einen Punkt fuer das drittbeste Bild Jedes Forumsmitglied kann einmal abstimmen, darf jedoch nicht fuer den eigenen Beitrag stimmen. Der Gewinner setzt das Thema fuer die folgende Barnack Challenge.
