Would some of you have the experience of comparisons between the TL 11-23mm f3.5-4.5, and the 23mm/f2.0 lenses?
Thinking of those two lenses, they are the same price, though at 23mm, there's 2.5 stops difference, while the 11-23mm has more range to select from...
I mainly using a 35mm/f14 ASPH-M on the M film cameras, therefore the 35mm range is preferably needed also on the new CL, thinking of selling the 21/f2.8ASPH-M to get either the 11-23mm, or the 23mm/f2 but not quite sure which one is more appropriate or worth to have to use on the CL?
for upper range, I can use the 35mm, the 50mm for the 50mm-75mm (on the CL format).
