Showing results for tags '50 mm apo lens barrel loose'.
Found 1 result
  1. The forward portion, containing the lens elements, of my lens was a bit loose when delivered. There is no apparent degradation of images or focusing. You can rotate the rim maybe 1/2mm in either direction or shift it up/down and left/right the same amount with respect to the rear mount assembly. User in U.S. Has anyone else noticed this with his lens? Does it have to go to Germany to be safely repaired? Thanks.
Γ—
Γ—
