The Leica Forum uses cookies. Read the privacy statement for more info. To remove this message, please click the button to the right:    OK, understood.
Tele-Elmar 135 lens cap with hood reversed
  • Please log in to reply
4 replies to this topic
#1 ron_a
ron_a
    Neuer Benutzer
  • Members
  • PipPip
  • 20 posts
  • City / Ort:Helena
Posted 29 September 2008 - 22:41
Advertisement (Gone after free registration)
When the hood on the tele-elmar 135 is reversed what lens cap goes on the hood?
Is it a special cap or is it a standard size?
I found information on a cap for the lens when the hood is left in place which I understood was a 55 mm snap cap - is that information correct?
#2 cbretteville
cbretteville
    Sponsoring Member
  • Premium Member
  • 3,337 posts
  • City / Ort:Oslo, Norway
Posted 29 September 2008 - 23:13
Ron,
The 12575 hood takes a 14033 cap. This is the same cap used for the 12585 hood used on 50 and 35 crons. It looks something like this from the back
[ATTACH]105380[/ATTACH]
- Carl
#3 Shootist
Shootist
    Erfahrener Benutzer
  • Members
  • 5,728 posts
  • City / Ort:Atlanta
Posted 29 September 2008 - 23:14
If it's the hood I'm thinking of, same as the the one for the 90mm 12575N or some cryptic letter/number combo, with push bars on the side to retract the locking lugs it is a special cap of a special size that has cutouts to go around the push bars. Very hard to find when you want one. Fairly easy to find when you have no interest in it.
#4 robsteve
robsteve
    Erfahrener Benutzer
  • Members
  • 2,432 posts
Posted 29 September 2008 - 23:41
There is also a cap that mounts flush and locks in with the locking pins inside the hood.
If you are using a 39mm UV-ir filter, a modern Leica 39mm cap will fit with the hood reversed because the filter threads stick out far enough for the modern cap to engage into them.
#5 cbretteville
cbretteville
    Sponsoring Member
  • Premium Member
  • 3,337 posts
Posted 29 September 2008 - 23:49
Aahh, you're right. The standard, current, Leica E39 cap (14038) works just fine too, as long as there is a filter mounted on the lens (mine is a B+W).
- Carl
0 user(s) are reading this topic
