The Leica Forum uses cookies. Read the privacy statement for more info. To remove this message, please click the button to the right:    OK, understood.
Leica 30-90mm Vario-Elmar-S Review
Leica Vario-Elmar-S 30-90mm Leica S
  • Please log in to reply
20 replies to this topic
#1 Vieri
Vieri
    Leica Ambassador
  • Members
  • 988 posts
  • LocationSan Ginesio, Italy
  • City / Ort:San Ginesio, Italy
Posted 19 March 2017 - 17:12
Advertisement (Gone after free registration)
Today I published an article dedicated to the Leica 30-90mm Vario-Elmar-S in the field on the Leica S (007), including my consideration about using it on the Leica SL. Here it is:
https://vieribottazz...ser-report.html
Hope you'll enjoy the read and images! Best,
Vieri
Edited by Vieri, 19 March 2017 - 17:12.
  • albertknappmd, Photoskeptic, mgrayson3 and 2 others said thank you
Vieri Bottazzini | Leica Ambassador | ABIPP EP
VIERI BOTTAZZINI PHOTOGRAPHER
VIERI BOTTAZZINI WORKSHOPS
#2 Jeff S
Jeff S
    Erfahrener Benutzer
  • Members
  • 9,949 posts
Posted 19 March 2017 - 21:44
There is apparently some sample variation regarding edge performance.....in this thread, Manolo's turned out to be out of spec and Leica addressed it to some extent...  http://www.l-camera-...st-impressions/
Regarding your comparison to the SL 24-90, you omitted the image stabilization of the SL zoom, which is especially important for handheld use.  Handheld, the faster SL zoom, coupled with both IS and AF, should be easier to obtain sharp results in less than ideal light... aided by its better edge performance and weather sealing.  A sharp smaller file beats a fuzzy larger file.
I demo-ed the S006 and 30-90 for a week last Summer, but was disappointed with handheld results in all but good daylight.  This was exacerbated by the optional spit image screen in the S006, which tended to half black out when using the longer, slower end of the zoom.  For tripod work, at faster speeds, this of course would not be an issue.  I'm sure that the zoom coupled with the newer, faster S007 would have fared much better for handheld use.
Jeff
  • djmay said thank you to this
#3 Vieri
Vieri
    Leica Ambassador
  • Members
  • 988 posts
Posted 19 March 2017 - 22:03
Jeff
Jeff,
1. There is sample variation indeed; I mentioned that I found a good used copy, before that I tried a not-so-good one which was from a lens test pool and was decentered; but in the name of fairness I didn't mention it in the article because the lens obviously had a rough life (looked pretty knocked);
2. About the SL, I said "If you are a Leica SL owner and you don’t own or plan on owning a Leica S, I would definitely recommend getting the SL’s native 24-90mm Vario-Elmarit-SL over the 30-90mm Vario-Elmar-S. The 24-90mm Vario-Elmarit-SL has amazing image quality, it’s wider, faster, lighter, easier to filter and its AF is much faster; at half the price of the 30-90mm Vario-Elmar-S it’s a no brainer. However, if you are a Leica S owner and you either already own or are thinking about getting a Leica SL for backup or to complement your S system, the 30-90mm Vario-Elmar-S is a lens you might want to consider: not only it works perfectly on the Leica SL, but here the corner softness at longer focal lengths is all but absent.".
I never compared the 24-90 on the SL with the 30-90 on the S; I compared both lenses on the SL only, and strongly recommended getting the 24-90mm, so I don't see what your point exactly is: we seem to agree on this. However, perhaps I didn't explain myself very well, or you didn't read that part of the article with enough attention: since both lenses are used on the SL as you can see from the paragraph above, I don't see where you get your "A sharp smaller file beats a fuzzy larger file", since both files are actually from the same camera, the SL, and therefore are of the same size :) More, the Vario-Elmar IS weather sealed as the 24-90mm, and it has great corner-to-corner sharpness on the SL, where it uses only the central portion of the image circle.
Btw, I'll add image stabilisation in the 24-90mm advantage list, thanks for that - obviously I forgot to include it.
3. About your last sentence, I used it on the S 007 only, so I cannot comment on the lens' performance on the S 006, and even less so if you add a split screen instead of the original screen. Of course, AF in low light with a f/5.6 lens is going to be poorer than with a f/2.5 lens, and of course handholding a f/5.6 lens on medium format in low light is going to be tough - no surprise there. I also don't understand your "For tripod work, at faster speeds, this of course would not be an issue.": if you are on a tripod, you'd use SLOWER speeds, not faster speeds for which you don't need a tripod at all.
Best,
Vieri
  • ynp and djmay said thank you to this
#4 Jeff S
Jeff S
    Erfahrener Benutzer
  • Members
  • 9,949 posts
Posted 19 March 2017 - 22:23
Of course I meant slower shutter speeds (allowing for smaller apertures).
The rest are my own observations, not a direct commentary on your comparisons, other than to add IS to the equation.  I just happen to be comparing the S and SL for my own use, including potential zoom applications.  In that regard, IS is a significant factor for me.
Likewise, the comments about the 006 have nothing to do with your comparison; they reflect my own experience with the 30-90 for anyone interested.
I understood your article just fine.....thanks for the review.
Jeff
Edited by Jeff S, 19 March 2017 - 22:24.
#5 Vieri
Vieri
    Leica Ambassador
  • Members
  • 988 posts
Posted 20 March 2017 - 08:17
Jeff
Ah ok then. Being that you wrote what you wrote as an answer to my post and since you didn't mention that what you wrote were just your own observations, I thought that you were... answering to my post :) All clear now.
Best,
Vieri
#6 ynp
ynp
    Erfahrener Benutzer
  • Members
  • 476 posts
Posted 20 March 2017 - 15:08
Thanks for your review. Very nice photos too.
I don't plan to buy the 24-90 for my SL for the current prices and I am happy with my M lenses on the SL. I have the S30-90 and use it on my SL sometimes. As an amateur and an occasional user of my Leicas, I tend to use what I have.
I am surprised that the Cheaper Than Ever Non-CS S lenses do not attract more attention of the SL crowd.
#7 Jeff S
Jeff S
    Erfahrener Benutzer
  • Members
  • 9,949 posts
Posted 20 March 2017 - 15:45
Maybe not too surprising given AF and service concerns, lack of IS, and still relatively pricey by most all standards except compared to their initial prices. And I think many SL users are making due with R and M lenses and the SL zooms until more native lenses reach market.
Jeff
#8 albertknappmd
albertknappmd
    Afficionado
  • Members
  • 884 posts
  • LocationNew York
  • City / Ort:New York
Posted 20 March 2017 - 17:17
excellent review....
as to Zoom creep... I had Leica tighten the lens ring in question and .... no more zoom creep..
I still use it at 90mm but crop out the  corners if they are really soft.
Albert  :D  :D  :D
#9 xiaubauu2009
xiaubauu2009
    Neuer Benutzer
  • Members
  • 303 posts
Posted 21 March 2017 - 05:17
My experience with the 30-90 is a mix bag. It's very versatile as we all know, but I think my copy has some issue as the image quality at 90 is not what I would say Leica quality. Complexity of the 3x zoom in a small package has its limitation I guess.
But as a 1 lens travel kit, this is unbeatable.
  • helged said thank you to this
#10 albertknappmd
albertknappmd
    Afficionado
  • Members
  • 884 posts
  • LocationNew York
Posted 21 March 2017 - 23:15
You are quite correct on all counts... The zoom is a funny creature and I have seen significant quality divergences.. However, if you get the right one you are golden... I returned the first two I received immediately until I got the third iteration which has been superb.. The old adage, three is a charm, is quite apposite...
Albert   :)  :)  :)
#11 FlashGordonPhotography
    Erfahrener Benutzer
  • Members
  • 1,736 posts
  • City / Ort:Terrigal, NSW
Posted 22 March 2017 - 04:29
I have two copies of the 30-90 (long story). Neither is perfect. The first one I got is terrible. Corners are mush at any aperture. 2nd it dramatically better but not great at any aperture. I have a 15-20 year old Pentax 45-85 and it positively stomps on the A$13K Leica at f8 and above. The corners are embarrassing on the Leica. Both copies.
However I have seen images from the 30-90 @90mm that were great at f8. Sample variation seems rife.
I have talked to Leica Australia about it and they're keen to assist but I haven't had time to pursue it further, yet.
If the 30-90 was stellar it would go a long way to making the S a great landscape camera (with LENR and long exposure fixes as well). Such a shame.
Gordon
#12 erlingmm
erlingmm
    Erfahrener Benutzer
  • Members
  • 617 posts
  • City / Ort:Oslo
Posted 22 March 2017 - 17:35
Just did an informal test of my S 30-90 Zoom, handheld at my local brick walls
DNGs uploaded to:
https://www.dropbox....xhgBpswlha?dl=0
2 sequences of 5 shots, taken at max aperture at 30, 45, 60, 75 and 90 mm
Auto Tone for synchronised exposure
I think this is quite good, even at 90mm despite some softness in the corners (not sharpened), a low res example at 90 mm here:
Attached File  L3002237.jpg   430.14KB   13 downloads
Edited by erlingmm, 22 March 2017 - 17:46.
  • helged and mgrayson3 said thank you to this
- ErlingMM
Edelknipser
#13 Vieri
Vieri
    Leica Ambassador
  • Members
  • 988 posts
Posted 23 March 2017 - 11:04
The 30-90mm is a very versatile lens, and if you get a good copy is perfectly good for all online publishing and small prints work. However, I have yet to find a copy that was great at the longer focal lengths; my second one was wonderful between 30-50mm, very good up to 60-70mm and had soft corners after that, again nothing problematic except for critical use.
About the S lenses, they can be had for a (very relative) song if used; and if you are interested in the S system I really think this is a very good time to stock them. The AF problem seem to have found a permanent fix, and if the rumours are correct we will see a new body relatively soon: if this happens, you can be sure that you'll not be able to find bargains on S lenses any more.
Gordon
Gordon, agree 100% with you: a stellar 30-90mm and serious long exposures would make for THE best landscape system around, if you ask me. Let's hope Leica is listening :)
Best,
Vieri
#14 leicapages
leicapages
    Erfahrener Benutzer
  • Members
  • 353 posts
  • City / Ort:Belgium
Posted 26 March 2017 - 11:45
Vieri
Now you make me curious. What rumors? Anything of substance?
#15 erlingmm
erlingmm
    Erfahrener Benutzer
  • Members
  • 617 posts
  • City / Ort:Oslo
Posted 26 March 2017 - 22:43
The S007 is 1,5 years old (delivered), I think it is too early to expect a new model. Neither have I heard any rumours, except wishful thinking that really goes in all directions.
Edited by erlingmm, 26 March 2017 - 22:45.
- ErlingMM
Edelknipser
#16 John McMaster
John McMaster
    Erfahrener Benutzer
  • Members
  • 658 posts
  • City / Ort:Occitanie
Posted 27 March 2017 - 17:16
My 2014 bought 30-90 aperture stopped working, sent to Wetzlar and a free repair:
Rebuilding the Autofocus
Renew the mask
General adjustment
john
#17 Vieri
Vieri
    Leica Ambassador
  • Members
  • 988 posts
Posted 28 March 2017 - 10:51
Well, obviously you shouldn't take delivery date as a reference (delivery of what? 1st camera? Widely available stock? How do you define that? etc). The 007 has been announced at Photokina 2014, so about 2.5 years ago. I can see a Photokina 2017 announcement of a replacement, a 3-year cycle is very likely especially considering the pixel count still stuck at 37 after the first S - plus, I have been seeing and hearing rumours around, mentioning either September or November as a possible date. I guess we'll have to wait and see, but certainly the 007 is due for a refreshment IMHO (and we'll definitely need at least a FW update adding long exposures) :) Best,
Vieri
#18 leicapages
leicapages
    Erfahrener Benutzer
  • Members
  • 353 posts
Posted 30 March 2017 - 22:18
Next Photokina is 2018 I thought, not 2017 (every two years).
#19 Jeff S
Jeff S
    Erfahrener Benutzer
  • Members
  • 9,949 posts
Posted 30 March 2017 - 22:33
Indeed.
Jeff
#20 Vieri
Vieri
    Leica Ambassador
  • Members
  • 988 posts
Posted 31 March 2017 - 11:59
True, no Photokina this year, a Photokina-time-of-the-year announcement is what I meant :)
Also tagged with one or more of these keywords: Leica Vario-Elmar-S, 30-90mm, Leica S
0 user(s) are reading this topic
