M6TTL - stuck frame selector
My M6TTL, bought almost a year ago, appears to have the frame selector stuck in the 35mm position (well, I think it's the 35mm position).  Doesn't change when I change the lens from 35 to 50 or 90, and no switching happens when I try to move the lever either (it moves very slightly, but nothing happens in the viewfinder).
I've found some previous posts asking about this, which mostly suggest 'I'd get a CLA and see if it works'.  Rather than that reply - has anyone else had this?  And how did they repair it?  And what is the likely cost?
many thanks
My MP did this and it's simply a matter of sending it to someone to clean out the dirt that is preventing the frame line masks from moving correctly. And while the camera is apart, you might as well get everything else checked and adjusted.
