The Leica Forum uses cookies. Read the privacy statement for more info. To remove this message, please click the button to the right:    OK, understood.
Complete beginner "my first camera is the Q" help and tips please
  • Please log in to reply
33 replies to this topic
#21 ropo54
ropo54
    Neuer Benutzer
  • Members
  • 515 posts
Posted 07 January 2017 - 20:05
Advertisement (Gone after free registration)
"Most of the things you can do with Lightroom, for retouching often Photoshop Elements is more convenient. A fantastic tool is the Nik Filter collection which is provided by Google as a free download and works as plug-in for LR and PSE."
Yes, the NIK filter is terrific. And, it is free.
Rob
Edited by ropo54, 07 January 2017 - 20:05.
  • Iduna and Bongo said thank you to this
#22 Bongo
Bongo
    Member
  • Members
  • PipPip
  • 16 posts
Posted 10 January 2017 - 00:43
Thanks I downloaded the Nix filters, and will have a play with these I assume is a simple version of Lightroom.
Cheers
#23 Bongo
Bongo
    Member
  • Members
  • PipPip
  • 16 posts
Posted 10 January 2017 - 03:09
I was wondering what would be a good all round recommend suitable SD card for the Q, in terms of speed etc?
Thank you
#24 leetmode
leetmode
    Member
  • Members
  • PipPip
  • 16 posts
Posted 11 January 2017 - 04:23
Thank you
The Q uses UHS-I SD cards so the best in that category would be something like this, which is what I use. You can get a UHS-II SD card and still use it although the Q will not be able to take advantage of its write speed at 260 MB/s, vs 90 MB/s which is the Q's max. That being said, if you remove the SD card from the camera and plug it in via a compatible card reader you can transfer photos at 300 MB/s, unlike a UHS-I card which can only do 95 MB/s. I'm planning on picking up a UHS-II card soon.
#25 microview
microview
    Erfahrener Benutzer
  • Members
  • 1,628 posts
Posted 11 January 2017 - 22:31
One thing not touched on: it's best not to think of the Q as a 28mm Leica camera with free 35mm and 50mm lenses thrown in! The 35mm menu crop still produces a decent sized file and in LR you can shift the precomposed area around over the full size RAW file and recompose/crop. With the current software you can have manual focus with/without centre magnification, and you might prefer focusing the whole frame. However the autofocus is so good that you can virtually rely on it full-time. As for IQ with that 1.7 lens – wow! A great camera and significantly less heavy to lug around than the Ms, although I do think the grip is a great help, and not much trouble to unscrew to access the battery/card compartments.
  • Bongo said thank you to this
#26 Bongo
Bongo
    Member
  • Members
  • PipPip
  • 16 posts
Posted 11 January 2017 - 23:16
In terms of setting the Q to full AF, so it becomes a point and shoot for fast street shots, what would be the ideal settings I am asking as I wondered if it is better to keep on PSAM setting or to now and agin use just pain AF setting just to get an idea of what the camera can actual do without using any settings.
I would be keen to know what other setting I should change before setting to full AF.
Thanks
#27 marchyman
marchyman
    Erfahrener Benutzer
  • Members
  • 332 posts
  • LocationSan Francisco Bay Area
Posted 12 January 2017 - 02:59
Most other settings will effect composition or exposure.   They will have little effect on focus.
For focus you can select manual or auto.  See page 174 (or there abouts) of the manual for the various settings available when using autofocus.  For manual focus you have the option to have the camera zoom when turning the focus ring and you can also  enable focus peaking.
Put the camera on auto aperture, auto speed, and auto iso.  Now with everything pertaining to exposure automated concentrate on playing with the various focus combinations.   The goal is to find out what works for you.   Ignore aspects of the test images you take except focus.   After you get comfortable and find out what focus you like in various picture taking conditions you'll be able to move on to playing with other settings.
  • Herve5 and Bongo said thank you to this
#28 Bongo
Bongo
    Member
  • Members
  • PipPip
  • 16 posts
Posted 12 January 2017 - 03:16
Thanks thats very helpful, I am going to explore taking images using the auto focus, with ISO, auto statue and auto speed. then take some test photos.
Then will experiment using all settings to auto as you suggested, but using manual focus and focus peaking to assist me, and then compare. the camera zoom in manual is helpful, and I have found this works well, I suppose auto is great if your taking many shots fast, and you can take some shots in continuous mode and some will be in focus and some will not.
The image quality though even in my very amateur hands is great, am so pleased with my Q.
Cheers
#29 Jk1002
Jk1002
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 16 January 2017 - 16:45
http://www.leica-aka...undamentals.pdf
This is fairly epic for a to the pount introduction
  • MickyW, Herve5, Macberg and 1 other said thank you
#30 Bongo
Bongo
    Member
  • Members
  • PipPip
  • 16 posts
Posted 16 January 2017 - 19:15
wow thanks that is epic but so so helpful, many many thanks,
Cheers for all your help
#31 fastcar888
fastcar888
    Advanced Member
  • Members
  • PipPipPip
  • 68 posts
  • LocationSouth Florida
Posted 18 January 2017 - 03:03
A a 28mm lens without the proper software for cropping can be a problem; it does have its limitations.  The same is true regarding software. With proper software, the Leica Q with its 28mm lens can be dazzling.
You may want to consider an Adobe product, like Lightroom and Photoshop, in conjunction with ON1 Photo 10. Rarely, do I end up with a photo that does not incorporate  Lightroom and ON1 Photo 10. ON1 Photo 10 can provide stunningly beautiful finishes quite easily.  Check it out. Good luck.
#32 kmak817
kmak817
    Advanced Member
  • Members
  • PipPipPip
  • 54 posts
Posted 21 January 2017 - 18:44
I found this online course at Udemy well worth $15.  Thomas Leuthard is the instructor.  The topic is composition and I learned a fair number of (nonintuitive) basics from it.
https://www.udemy.com/composition/
You can also play the videos at higher speed and absorb the information faster.
#33 hirstwithaneye
hirstwithaneye
    Newbie
  • Members
  • Pip
  • 3 posts
Posted Today, 12:28
My thought for someone 'just getting started' would be to just use your camera as much as you can, every day just take a picture of *something*, *anything*, to stay familiar with it & to learn a little more about how it works under every circumstance.
I've fallen into a terrible habit of using my iPhone for this kind of casual / day-to-day photography and have "been saving my Q for best" - a consequence is every time I pick it up I have to think about it a little first & it's not yet instinctive in my hands.  Try using your camera (not just a Q, any camera) every day in every way and you'll always be ready and continually be learning - how does it work best indoors, outdoors, at night, at noon, for sunset, with kids / dogs / cars? etc etc.
I learned on an Olympus film SLR in 80's and had to wait (and pay heavily) for my feedback 7x5 prints a week later, so taking 200 digital photos in a day (and deleting nearly all of them) is such a joy by comparison & must be accelerating the learning curve.
Have fun.
  • Infiniumguy and Bongo said thank you to this
#34 Bongo
Bongo
    Member
  • Members
  • PipPip
  • 16 posts
Posted Today, 15:26
Thank you for all the great advice and information, will be trying to use my camera as much as I can, while I explore by trial and error [probably errors than anything else] LoL
Cheers
2 user(s) are reading this topic
Leica Deals
