Jodad Posted September 6, 2016 Share #1 Posted September 6, 2016 (edited) Advertisement (gone after registration) So apparently there is both a brass version and nickel of the leica 50 3.5 elmar. Also around 1954 there was a change between E39 and a36 so 36 and 39 mm. Can someone explain the difference between the quality of the brass and nickel versions? Is one better than the other? im not a chemist or metalurgist... What do the two "sizes" refer to? And also, were all the same (old ) accesories made available for each size? Thanks for your time guys! Edited September 6, 2016 by Jodad Quote Link to post Share on other sites More sharing options...
Advertisement Posted September 6, 2016 Posted September 6, 2016 Hi Jodad, Take a look here Question about Elmar material and 36 v 39 size?. I'm sure you'll find what you were looking for!
earleygallery Posted September 6, 2016 Share #2 Posted September 6, 2016 Earlier lenses were nickel plated, then chrome plating became standard. They're all brass. The numbers refer to filter size. A36 are clamp on filters. E39 is 39mm threaded filter size. The later f3.5 E39 lens was only made in M mount, but you can buy the 50 f2.8 version in LTM mount. Quote Link to post Share on other sites More sharing options...
Jodad Posted September 6, 2016 Author Share #3 Posted September 6, 2016 Thanks a lot earleygallery. Simple enough. So for an iiig it's just the a36 and either nickel or chrome ( the latter just coming down to a matter of looks) Have I got it right? Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted September 7, 2016 Share #4 Posted September 7, 2016 (edited) Thanks a lot earleygallery. Simple enough. So for an iiig it's just the a36 and either nickel or chrome ( the latter just coming down to a matter of looks) Have I got it right? Yes if you consider only the classic Elmar f 3,5... as James said, the Elmar f 2,8 (E39 filter) does exist in screw Mount... and, by the way, is one of the lenses that better matches a IIIG in "historical" terms : the Elmar f 2,8 was introduced the same year of the IIIG, and the IIIG itself was listed as body only, body with Elmar f 2,8, body with Summicron f2... not with the Elmar f 3,5 which , in the screw mount version, was in practice no more built in the years of IIIG production. About accessories... the f 2,8 cannot be used with the classic near focusing accessory NOOKY... which anyway doesn't fit the IIIG , but only the previous bodies : IIIG uses a different accessory for the same function (ADVOO) which, not by chance, works with Elmar 2,8 and not 3,5 (it includes an E39 near focus dipotre lens) Edited September 7, 2016 by luigi bertolotti Quote Link to post Share on other sites More sharing options...
wizard Posted September 9, 2016 Share #5 Posted September 9, 2016 IMHO, the perfect match for a Leica IIIg is a collapsible Summicron 5cm lens, while a IIIf blends nicely with the Elmar 3,5. Don't know why, but try out yourself and you will see it's true. Andy 1 Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted September 9, 2016 Share #6 Posted September 9, 2016 IMHO, the perfect match for a Leica IIIg is a collapsible Summicron 5cm lens, while a IIIf blends nicely with the Elmar 3,5. Don't know why, but try out yourself and you will see it's true. Andy I agree... a IIIG set imho has 3 main "flavors" - "the honest" : body with Elmar 2,8 - "the fine" : body with Summicron collpsible - "the ultratasty" : body with Leicavit and Summilux LTM Quote Link to post Share on other sites More sharing options...
Jodad Posted September 12, 2016 Author Share #7 Posted September 12, 2016 Advertisement (gone after registration) I agree... a IIIG set imho has 3 main "flavors" - "the honest" : body with Elmar 2,8 - "the fine" : body with Summicron collpsible - "the ultratasty" : body with Leicavit and Summilux LTM HILATIOUS! I will take a look. Thanks all! Quote Link to post Share on other sites More sharing options...
