Leica T Cover for the Q
Hello,
I always wanted to have a coloured Q like the Leica T, now the time has come. I think the Cover of the Q looks very fierce, also it’s more solid than the Leica grip. This one wobbles a little bit. I also changed the design. The diameter is somehow different. It took me five times to construct the perfect grip. The thread for the application ¼ (tripod plate) was printed and works very well.
-Software Solidworks 2016
-Prototypes total five pieces
-Printing time 8h
-Glue felt on the inside 45min
Regards,
Lukas
Edited by Snooopy
Leica Q stealth-cover without Leica-Red-Dot  :)
OK. This version I like. It looks stealthy and does away with the need for a grip. Do you propose to incorporate access to the camera base? I would also suggest the internal dimensions should make space for a permanent soft lining. What is the rear like?
How would this item be marketed in bulk or do you propose special orders for single unit print?
Amended post: I can see from the earlier design that access to card and battery is incorporated and glued felt internally.
Edited by lucerne
The cover has  inside a soft inlay like the orignal Leica hand grip. The yellow cover from behind on a tripod it`s the same design.
  • 1 month later...
  • 1 month later...
