xiaubauu2009 Posted August 3, 2016 Share #21 Posted August 3, 2016 Advertisement (gone after registration) I am using Billingham Packington. With a lens attached and one extra lens vertical. I have minitripod and other stuff including filters and stuff in the other space. Quote Link to post Share on other sites More sharing options...
Advertisement Posted August 3, 2016 Posted August 3, 2016 Hi xiaubauu2009, Take a look here Need some advice on a compact bag for the Leica S. I'm sure you'll find what you were looking for!
Jeff S Posted August 3, 2016 Share #22 Posted August 3, 2016 One nice thing about the Hadley Pro is its top handle (reinforced, too). If I purchased one of the other Billingham's mentioned above, I'd inquire about the cost of adding a similar handle. Jeff Quote Link to post Share on other sites More sharing options...
albireo_double Posted August 3, 2016 Share #23 Posted August 3, 2016 Billingham Eventer would also work for your purpose, I think. Quote Link to post Share on other sites More sharing options...
Manolo Laguillo Posted August 3, 2016 Share #24 Posted August 3, 2016 (edited) One nice thing about the Hadley Pro is its top handle (reinforced, too). If I purchased one of the other Billingham's mentioned above, I'd inquire about the cost of adding a similar handle. Jeff True, the Hadley Pro's handle is beautiful! I asked Billingham about fitting one on the f.1.4 and other bags, and the answer was 'no way, it would affect the stability'. Therefore I did found my own solution. It consists basically in adding 2 leather pieces, which I bought in a saddler's shop. The attached pictures will show it. In reality it looks nicer than in these pictures... :-) Only caution: the bag must be closed when holding it from this handle, because it can tip over. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited August 3, 2016 by Manolo Laguillo 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/263112-need-some-advice-on-a-compact-bag-for-the-leica-s/?do=findComment&comment=3089861'>More sharing options...
Manolo Laguillo Posted August 3, 2016 Share #25 Posted August 3, 2016 The 2nd picture Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/263112-need-some-advice-on-a-compact-bag-for-the-leica-s/?do=findComment&comment=3089865'>More sharing options...
Manolo Laguillo Posted August 3, 2016 Share #26 Posted August 3, 2016 And this is the entire bag Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/263112-need-some-advice-on-a-compact-bag-for-the-leica-s/?do=findComment&comment=3089866'>More sharing options...
leicapages Posted August 3, 2016 Author Share #27 Posted August 3, 2016 Advertisement (gone after registration) Billingham f.1.4 + S + 30-90 + 70.jpg S + 30-90 + 70. That's what I have, exactly. Even with the lenshood in working position on the 30-90 everything fits well into the Billingham f.1.4. This bag is very light (lighter than the Hadley Pro, or the Peak Design's Messenger), the equipment is well protected, it is rainproof, and it is an "open space" bag, with everything easily reachable. I own the Billingham Hadley Pro as well, but the S + any lens would not have enough place in it. I had the "Leica large cotton system case", but I sold it. A very nice bag, strong and soft, very good looking. But too large for the M, as I saw it (I don't like to carry so much stuff when working with the M), and too narrow for the S... BTW, the best Billingham for a compact M outfit is the L2. This bag is much better than the Leica Billingham. Thanks a lot for these images, the bag looks indeed like what I need. I will try to check it out, together with the Hadley Pro, to make up my mind 1 Quote Link to post Share on other sites More sharing options...
leicapages Posted August 3, 2016 Author Share #28 Posted August 3, 2016 I'm using a Harley Pro for mine and I can get my S007 with 30,70 & 120 in it plus some assesories Sent from my iPhone using Tapatalk Neil, am curious to see how the Hadley Pro would work for S + vario 30-90 and 70 lenses. Most said it wouldn't work but according to Billingham itself, both the Hadley Pro and the fStop 1.4 series should work... But the Hadley Pro is quoted to be narrower than the fStop 1.4, so that may be problematic. Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted August 3, 2016 Share #29 Posted August 3, 2016 Neil, am curious to see how the Hadley Pro would work for S + vario 30-90 and 70 lenses. Most said it wouldn't work but according to Billingham itself, both the Hadley Pro and the fStop 1.4 series should work... But the Hadley Pro is quoted to be narrower than the fStop 1.4, so that may be problematic. How big is the zoom lens compared to my 30mm Summilux??? Quote Link to post Share on other sites More sharing options...
John McMaster Posted August 3, 2016 Share #30 Posted August 3, 2016 Wow, you have a 30mm Summilux!!! The zoom is bigger (longer and wider, 95mm filter) than the 35mm Summarit john Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted August 3, 2016 Share #31 Posted August 3, 2016 How big is the zoom lens compared to my 30mm Summilux??? Sent from my iPhone using Tapatalk Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted August 3, 2016 Share #32 Posted August 3, 2016 One picture with 30 attached the other with 70 arrached Sent from my iPhone using Tapatalk Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted August 3, 2016 Share #33 Posted August 3, 2016 I then put my 120 in the front left hand pocket Sent from my iPhone using Tapatalk Quote Link to post Share on other sites More sharing options...
John McMaster Posted August 3, 2016 Share #34 Posted August 3, 2016 From Leica's website....... Zoom: length 113/143 (w and w/o hood) and max diameter 101/150 30: length 128/156 and max dia 88/132 So shorter but wider... john Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted August 3, 2016 Share #35 Posted August 3, 2016 I've been thinking about getting the zoom and doing away with my 30 & 70 but I've read the IQ of the zoom is terrible compared to the primes............ So I think I will stick with what I already have. Sent from my iPhone using Tapatalk Quote Link to post Share on other sites More sharing options...
John McMaster Posted August 3, 2016 Share #36 Posted August 3, 2016 Also there is no CS available with the zoom.... john Quote Link to post Share on other sites More sharing options...
Printmaker Posted August 3, 2016 Share #37 Posted August 3, 2016 That's a serious bulge in your Hadley, Neil. I find the Hadley pro is a better fit for my M cameras. It holds 2 bodies with lenses, 2 additional lenses, flash and a computer without straining the straps. It is my under-the-seat airline bag. When I'm situated, I usually just use one camera and leave the kit in my room. The Filson is wider, deeper and more casual looking. But it does tend to fill up with rain jackets and the little crap my wife picks up when we're out. Unless, of course, it is hauling her Olympus kit along with the S2. In that case she carries her own shopping bag. Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted August 4, 2016 Share #38 Posted August 4, 2016 That's a serious bulge in your Hadley, Neil. I find the Hadley pro is a better fit for my M cameras. It holds 2 bodies with lenses, 2 additional lenses, flash and a computer without straining the straps. It is my under-the-seat airline bag. When I'm situated, I usually just use one camera and leave the kit in my room. The Filson is wider, deeper and more casual looking. But it does tend to fill up with rain jackets and the little crap my wife picks up when we're out. Unless, of course, it is hauling her Olympus kit along with the S2. In that case she carries her own shopping bag. Nothing wrong with a little bulge......... For me anyway its a perfect fit, I also have the Birmingham 335 that I sometimes use when traveling from A to B ............I will pack my Harley Pro in my check in luggage and then use the Harley pro for my walk around bag Quote Link to post Share on other sites More sharing options...
Jeff S Posted August 4, 2016 Share #39 Posted August 4, 2016 It must be a chore still lugging that Harley bike around. The Hadley is so much lighter. Jeff Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted August 4, 2016 Share #40 Posted August 4, 2016 But its sure a lot of fun Quote Link to post Share on other sites More sharing options...
