Jeffry Abt Posted February 13, 2016 Share #1 Posted February 13, 2016 Advertisement (gone after registration) Has anyone tried taking out ( with a tooth pick) the white paint in "Leica"? ....As is often done with the M. Just a question, I'm not complaining about the SL. But if I owned a SL, I might want the "Leica" to be a little bit more subtle. I really don't care for the gaffers tape solution. 2 Quote Link to post Share on other sites More sharing options...
Advertisement Posted February 13, 2016 Posted February 13, 2016 Hi Jeffry Abt, Take a look here Taking out the white LEICA paint.... I'm sure you'll find what you were looking for!
Jeffry Abt Posted February 13, 2016 Author Share #2 Posted February 13, 2016 I suppose not... Quote Link to post Share on other sites More sharing options...
profus Posted February 13, 2016 Share #3 Posted February 13, 2016 If I knew how I could do it without making any damage I would do it right away... Quote Link to post Share on other sites More sharing options...
pico Posted February 13, 2016 Share #4 Posted February 13, 2016 Acetone on a q-tip will remove it in a moment. 1 Quote Link to post Share on other sites More sharing options...
LocalHero1953 Posted February 13, 2016 Share #5 Posted February 13, 2016 (edited) Black PVC electrical insulating tape is barely noticeable and leaves the camera unharmed. Edited February 13, 2016 by LocalHero1953 Quote Link to post Share on other sites More sharing options...
Peter Walker Posted February 13, 2016 Share #6 Posted February 13, 2016 I don't see the need to do it. Also might reduce resale value. Quote Link to post Share on other sites More sharing options...
jcraf Posted February 14, 2016 Share #7 Posted February 14, 2016 Advertisement (gone after registration) Just acquired an SL yesterday. Having been used to a black M4, black M240P and an MM246, that L E I C A script does shout somewhat doesn't it? +1 for the black electricians tape, but I'd never remove the paint. Quote Link to post Share on other sites More sharing options...
keithlaban.co.uk Posted February 14, 2016 Share #8 Posted February 14, 2016 The first accessory I bought for my Leicas was black tape. Quote Link to post Share on other sites More sharing options...
dkCambridgeshire Posted February 14, 2016 Share #9 Posted February 14, 2016 (edited) Here's another way of creating an SL 'STEALTH' camera … but at your own risk: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1. Attach a piece of good quality adhesive tape across the LEICA logo … I used 20 year old 'Scotch Pressure Sensitive tape' … which has not yellowed over time. 2. Using a permanent black marker pen (I used a STAEDTLER Lumo colour permanent marker), apply ink onto the sticky tape to cover the logo 3. Use a wet finger to de-gloss the ink to a matt finish 4. On close inspection LEICA logo is still visible but from a distance unlikely anyone unfamiliar with cameras will realise it's a Leica The red dot can be similarly disguised. I've made two attempts at this and peeled off the first to make sure no damage had occurred to the matt black camera finish or the white logo. And I'm assuming the black marker pen ink will not bleed through the sticky tape onto the camera. The advantage of using thin sticky tape is that it's less visible than thicker proprietary black tape. I have used a very fine Staedtler permanent black marker pen to apply ink directly to the white shutter speed numerals on my M6 Titanium - to make them more visible against the titanium finish - but first tried on a small test area to ensure the ink can be removed using iso propyl alcohol. But would not recommend the same direct application procedure for the LEICA logo. As stated above … if you wish to try this it's at your own risk. There is a 23mm T lens attached to the camera. When I'm using my FD L lenses on the SL maybe inquisitive onlookers might think a Canon camera is in use … or a Sony Best wishes dunk Edited February 14, 2016 by dkCambridgeshire Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! 1. Attach a piece of good quality adhesive tape across the LEICA logo … I used 20 year old 'Scotch Pressure Sensitive tape' … which has not yellowed over time. 2. Using a permanent black marker pen (I used a STAEDTLER Lumo colour permanent marker), apply ink onto the sticky tape to cover the logo 3. Use a wet finger to de-gloss the ink to a matt finish 4. On close inspection LEICA logo is still visible but from a distance unlikely anyone unfamiliar with cameras will realise it's a Leica The red dot can be similarly disguised. I've made two attempts at this and peeled off the first to make sure no damage had occurred to the matt black camera finish or the white logo. And I'm assuming the black marker pen ink will not bleed through the sticky tape onto the camera. The advantage of using thin sticky tape is that it's less visible than thicker proprietary black tape. I have used a very fine Staedtler permanent black marker pen to apply ink directly to the white shutter speed numerals on my M6 Titanium - to make them more visible against the titanium finish - but first tried on a small test area to ensure the ink can be removed using iso propyl alcohol. But would not recommend the same direct application procedure for the LEICA logo. As stated above … if you wish to try this it's at your own risk. There is a 23mm T lens attached to the camera. When I'm using my FD L lenses on the SL maybe inquisitive onlookers might think a Canon camera is in use … or a Sony Best wishes dunk ' data-webShareUrl='https://www.l-camera-forum.com/topic/256818-taking-out-the-white-leica-paint/?do=findComment&comment=2989514'>More sharing options...
jaapv Posted February 15, 2016 Share #10 Posted February 15, 2016 I don't see the need to do it. Also might reduce resale value. It is easy enough to reapply if so desired. 1 Quote Link to post Share on other sites More sharing options...
ramarren Posted February 15, 2016 Share #11 Posted February 15, 2016 I've never hidden a logo on any camera I've owned. Very very few people notice that I have a camera at all, never mind whether it's a Leica or a Hasselblad, or whatever. Stealth is in the photographer, not in the camera. 1 Quote Link to post Share on other sites More sharing options...
scott kirkpatrick Posted February 15, 2016 Share #12 Posted February 15, 2016 I used to tape up Nikons when shooting in demonstrations in the '60s. Haven't bothered since. scott Quote Link to post Share on other sites More sharing options...
mike_j Posted February 15, 2016 Share #13 Posted February 15, 2016 An alternative is to print a logo of your choice:- "CANIKON" or "SONTAX" for example in white out of black on photopaper employing a Leica style font and paste it over the existing Leica logo. 2 Quote Link to post Share on other sites More sharing options...
dkCambridgeshire Posted February 15, 2016 Share #14 Posted February 15, 2016 An alternative is to print a logo of your choice:- "CANIKON" or "SONTAX" for example in white out of black on photopaper employing a Leica style font and paste it over the existing Leica logo. I'd print MESSIAH … being the R solution for which we've all waited and waited so patiently. dunk Quote Link to post Share on other sites More sharing options...
ynp Posted February 15, 2016 Share #15 Posted February 15, 2016 An alternative is to print a logo of your choice:- "CANIKON" or "SONTAX" for example in white out of black on photopaper employing a Leica style font and paste it over the existing Leica logo.Interesting. What tape do you recommend and how I could print ZONY or LOMO logo on it? I use the tape on my S2, I cover the FOBA sign as well when I shoot flat art and paintings and interiors. I am noticing the camera logo reflections in the images much more often than I would like them to see. Quote Link to post Share on other sites More sharing options...
pico Posted February 15, 2016 Share #16 Posted February 15, 2016 For large format I use a Canon backpack with the C removed. 1 Quote Link to post Share on other sites More sharing options...
ynp Posted February 15, 2016 Share #17 Posted February 15, 2016 For large format I use a Canon backpack with the C removed.Brilliant! Quote Link to post Share on other sites More sharing options...
profus Posted February 16, 2016 Share #18 Posted February 16, 2016 It is easy enough to reapply if so desired. How? Quote Link to post Share on other sites More sharing options...
farnz Posted February 16, 2016 Share #19 Posted February 16, 2016 You can use a Hobo Art Primo dry paint stick. And if you're adventurous you could use another colour all together or even a different colour for each letter if you wanted. Having the only SL with L E I C A in red might be quite attractive to some owners. Pete. 1 Quote Link to post Share on other sites More sharing options...
thighslapper Posted February 16, 2016 Share #20 Posted February 16, 2016 (edited) As the body is aluminium you can easily file it flat and remove all trace of LEICA completely. Just a lick of matt enamel paint or 5 minutes with sharpie/transparency pen and you will have greatly enhanced the resale value of your now unique 'STEALTH SL' Edited February 16, 2016 by thighslapper Quote Link to post Share on other sites More sharing options...
