Jon Pop Posted November 29, 2015 Share #1 Posted November 29, 2015 Advertisement (gone after registration) I have a SF24D which I use for my digital M cameras, but was wondering if there was a way to trigger it and use it with my iiig. I'm trying to find a cord that will connect to the outlet on the back on one end, with the hot shoe on the other to hold the SF24D. Haven't had much luck. Any suggestions? Is this impossible? Of course...no expectations of TTL ! I just want to trigger it. Quote Link to post Share on other sites More sharing options...
Advertisement Posted November 29, 2015 Posted November 29, 2015 Hi Jon Pop, Take a look here Flash use with iiig. I'm sure you'll find what you were looking for!
pico Posted November 30, 2015 Share #2 Posted November 30, 2015 (edited) I have a SF24D which I use for my digital M cameras, but was wondering if there was a way to trigger it and use it with my iiig. I'm trying to find a cord that will connect to the outlet on the back on one end, with the hot shoe on the other to hold the SF24D. Haven't had much luck. Any suggestions? Is this impossible? Of course...no expectations of TTL ! I just want to trigger it. Auto mode (where flash determines complete exposure) is better anyway. Kaiser PC to Hot Shoe Adapter I have used it on other cold shoes. There are so many that turn a hot shoe into a PC outlet (wrong way), and pass-throughs (not for us) that it is confusing. I ordered one and if you don't mind waiting I can try it before you buy. Edited November 30, 2015 by pico Quote Link to post Share on other sites More sharing options...
Michael Geschlecht Posted November 30, 2015 Share #3 Posted November 30, 2015 Hello Jon, The flash socket on a IIIg is the same socket as the standard PC socket used from the M4 up to today. You can use the electronic flash in a variety of manners with the top dial set to either of the 2 lightning bolts & the front dial set in various positions. There is a copy of the IIIg instruction book at the top of this page in the WIKI. The instructions explain the various options available for using the electronic flash in different situations/combinations. Best Regards, Michael Quote Link to post Share on other sites More sharing options...
pico Posted November 30, 2015 Share #4 Posted November 30, 2015 Michael, there might be a misunderstanding. Jon's IIIG has a cold shoe so the SF24D will not fire. However the IIIG does have a PC synch socket on the back. What he can do (from my suggestion above) is to use a shoe adapter that has the necessary contacts to fire the SF when the adapter is plugged into his PC socket. Quote Link to post Share on other sites More sharing options...
willeica Posted November 30, 2015 Share #5 Posted November 30, 2015 (edited) The Metz 20 C-2 works well on my IIIg and it will also give bounce flash. It comes with a nice little sync cord and it has auto settings for f2.8 and f5.6. It will work on manual with other f stops. The only slight issue with the Metz is that it sits better in later M shoes than in early M or LTM ones but this can be managed. I also have a PC to hot shoe adapter, similar to the Kaiser, which will work with other flash guns as well as the Metz. William Edited November 30, 2015 by willeica Quote Link to post Share on other sites More sharing options...
DAVIDMC100 Posted December 30, 2022 Share #6 Posted December 30, 2022 I just ordered a Kaiser PC to Hot Shoe Adapter to use with my IIIf. What should I set the synchro selector scale to? I have the red synchro scale. I have a SF 20 and a SF 40 flash. Quote Link to post Share on other sites More sharing options...
Anbaric Posted December 30, 2022 Share #7 Posted December 30, 2022 Advertisement (gone after registration) 1 hour ago, DAVIDMC100 said: I just ordered a Kaiser PC to Hot Shoe Adapter to use with my IIIf. What should I set the synchro selector scale to? I have the red synchro scale. I have a SF 20 and a SF 40 flash. According to the manual, you can set the shutter speed to 1/50 and the red sync dial to 20, or set the shutter speed to 1/25 and the red sync dial to 0. But perhaps someone who uses modern flashguns with the IIIf RD can confirm this still applies? Quote Link to post Share on other sites More sharing options...
qqphot Posted January 1, 2023 Share #8 Posted January 1, 2023 On 12/30/2022 at 11:36 AM, Anbaric said: According to the manual, you can set the shutter speed to 1/50 and the red sync dial to 20, or set the shutter speed to 1/25 and the red sync dial to 0. But perhaps someone who uses modern flashguns with the IIIf RD can confirm this still applies? Both of those work on my IIIf, yes. On 1/50 occasionally the flash catches the very extreme edge of the shutter curtain, but I attribute this to the camera being old and janky. And anyway it doesn't obscure more than a tiny sliver of the frame. 1 Quote Link to post Share on other sites More sharing options...
