steed Posted August 24, 2015 Share #1 Posted August 24, 2015 Advertisement (gone after registration) Hello all I have been away from the forum for some time, but return with renewed vigor and a Leicaflex Standard (first version). The meter is light sensitive, but very optimistic (it overexposes by several stops). The body is gorgeous, and I am wondering if anyone has experience with recalibrating original Leicaflex meters. Are they good enough when working properly to be worth recalibrating? Cost ranges? I am used to setting exposure without a meter in a variety of settings, but always like a meter around just the same. Any advice would be welcome. Regards John W Quote Link to post Share on other sites More sharing options...
Advertisement Posted August 24, 2015 Posted August 24, 2015 Hi steed, Take a look here Leicaflex standard: is meter calibration worth it?. I'm sure you'll find what you were looking for!
Michael Geschlecht Posted August 24, 2015 Share #2 Posted August 24, 2015 (edited) Hello John, Welcome back to you & the Mrs. Having an external meter which reads from an EV of 2 to an EV of 18 @ ISO 100/21 can be useful in many situations. The first Leicaflex uses a PX13/625 mercury oxide battery which is replaceable with a zinc air equivalent or the meter may be recalibrated so that it can use a silver oxide equivalent #357. Silver oxide batteries tend to produce more reliable results than their alkaline alternatives. Even if it is a meter that you would only use occasionally the advantage to having the meter done is: It is always with you when you are using the camera anyway: So you might as well have it operating. The meter covers a fixed angle of view that is the same as the angle of view of a 90mm lens (27 degrees diagonally). This is the same angle of coverage as the angle of coverage of an MR or an MR4 meter. Many people are happy as clams with this angle of coverage on their various film M's. Best Regards, Michael Edited August 24, 2015 by Michael Geschlecht Quote Link to post Share on other sites More sharing options...
tobey bilek Posted August 24, 2015 Share #3 Posted August 24, 2015 The cells age and yours is past its prime unless it was replaced along the line. Quote Link to post Share on other sites More sharing options...
Michael Geschlecht Posted August 24, 2015 Share #4 Posted August 24, 2015 (edited) Hello Again John, As usual, Toby's advice is well worth considering. Altho Cds meters, like the meter in an Original Leicaflex, are less prone to fatigue than their 20th Century selenium contemporaries. I know a number of people who have a variety of cameras with built in CdS meters or who have separate handheld CdS meters from that time period (1960's & 1970's), who have had no problems other than battery availability/conversion. Best Regards, Michael Edited August 24, 2015 by Michael Geschlecht 1 Quote Link to post Share on other sites More sharing options...
TomB_tx Posted August 25, 2015 Share #5 Posted August 25, 2015 A common problem with CdS cells is moisture penetration that lowers the normal high resistance in darkness. This can result in a meter that can be adjusted for "good" accuracy in higher light levels, but will think low light levels are brighter than they are. This happened to a couple of Leicaflex SLs of mine. The only way to get low light accuracy back was to find a technician with a replacement correct CdS cell, which Leica no longer has. Quote Link to post Share on other sites More sharing options...
steed Posted August 25, 2015 Author Share #6 Posted August 25, 2015 Thanks to all for the welcome back and sage advice. Given the diminished value of Standards lately, and the difficulty in fixing the metering issue, I will use the handheld and just enjoy the incomparable build of the 'flex. Quote Link to post Share on other sites More sharing options...
don g Posted August 26, 2015 Share #7 Posted August 26, 2015 Advertisement (gone after registration) My Leicaflex I bought on e-bay as is had a eaten up battery spring. After reading the repair manual it decided to just excavate around the remaining metal and cleaned and burnished the metal and tinned it with solder, then milled a channel to the center of the chamber and soldered a thin wire to the stub and filled the cavity with epoxy. Later I soldered a small metal spring to the center of the chamber with the wire then epoxied it in place. after inserting battery low and behold it worked. The reading compares with my Gossen and Sekonic meters. I'm glad that I didn't have to e calibrate it which would entail removing the top and more time spent. And as stated it covers about 90 degrees . llFirst results were great. Quote Link to post Share on other sites More sharing options...
Photon Posted October 16, 2015 Share #8 Posted October 16, 2015 Hello all I have been away from the forum for some time, but return with renewed vigor and a Leicaflex Standard (first version). The meter is light sensitive, but very optimistic (it overexposes by several stops). The body is gorgeous, and I am wondering if anyone has experience with recalibrating original Leicaflex meters. Are they good enough when working properly to be worth recalibrating? Cost ranges? I am used to setting exposure without a meter in a variety of settings, but always like a meter around just the same. Any advice would be welcome. Regards John W You didn't mention which battery you had installed when the meter indicated an overexposure. If it wasn't a mercury battery (hard to obtain now, of course), the cause of the inaccurate meter reading could be an incorrect battery voltage. I use a CRIS adaptor with a silver oxide cell in my Leicaflex and it works fine (differs from a handheld Gossen by one-half stop). There are less expensive alternatives available on eBay. The convenience of having an on-board meter is worth something to me. Quote Link to post Share on other sites More sharing options...
steed Posted November 13, 2015 Author Share #9 Posted November 13, 2015 Hello again all, and particularly to Photon It turns out that someone somewhere gave me a PX625 that was supposed to be equivalent to the old mercury cell, but was not. As a last resort, I bought Wein cells from Amazon, put one in the Leicaflex,(first version) and voila! The meter is reasonably accurate. I would caution all with a Standard to take the battery out when the camera is not in use because of the lack of an on-off switch on the first version. Regards Steed Quote Link to post Share on other sites More sharing options...
Michael Geschlecht Posted November 13, 2015 Share #10 Posted November 13, 2015 Hello John, For the most part it was only the early Original Leicaflex with the "pie shaped" frame counter window that did not have a meter shut off. Most of the "round" window'd later versions shut the meter off when the film advance was pushed in all the way & turned it on when the film advance lever was pulled out to the "stand off" position. Like with the later Leicaflex SL/SL2 models. Best Regards, Michael Quote Link to post Share on other sites More sharing options...
Photon Posted November 16, 2015 Share #11 Posted November 16, 2015 Hello again all, and particularly to Photon It turns out that someone somewhere gave me a PX625 that was supposed to be equivalent to the old mercury cell, but was not. As a last resort, I bought Wein cells from Amazon, put one in the Leicaflex,(first version) and voila! The meter is reasonably accurate. I would caution all with a Standard to take the battery out when the camera is not in use because of the lack of an on-off switch on the first version. Regards Steed I believe that in the absence of an on/off switch, one can just put a lens cap on the camera. The CdS photocell resistance becomes very high with no light striking it and, in effect, shuts the metering circuit off. I did this, successfully, for quite some time with a Spotmatic F, a camera that also lacked an on/off switch. It is worth commenting that Wein cells can self-discharge and, once activated, can run themselves down slowly even if outside of the camera. You might want to consider the CRIS adaptor or the like. There is a less expensive one listed on eBay now. Quote Link to post Share on other sites More sharing options...
bocaburger Posted November 18, 2015 Share #12 Posted November 18, 2015 I had several SL's and used the CRIS adapter, which I found much more satisfactory than Wein cells because the latter go flat rather quickly. I also believe there are hearing-aid batteries of the same size and voltage which will fit the washer/adapter from a Wein cell. Quote Link to post Share on other sites More sharing options...
