Tommy Hansen Posted July 15, 2015 Share #1 Posted July 15, 2015 Advertisement (gone after registration) I WANT to use a yellow filter and i think i NEED to use a lens hood against flare on my 35 3.5 Summaron (LTM). Is it possible to use a filter and the FOOKH lens hood together? My alternativ is to mount a SOOGZ adapter on the lens and then use a 39mm filter and some kind of screw on lens hood. How deep/long are the FOOKH hood? /Tommy Quote Link to post Share on other sites More sharing options...
Advertisement Posted July 15, 2015 Posted July 15, 2015 Hi Tommy Hansen, Take a look here Filter + FOOKH together on 35 3.5 Summaron?. I'm sure you'll find what you were looking for!
luigi bertolotti Posted July 16, 2015 Share #2 Posted July 16, 2015 (edited) Yes : I understand that your LTM Summaron is the A36 version : in this case, if you use the standard Leitz A36 clamp-screw filters, you can mount onto them the FOOKH ; is a standard configuration : all the Leitz A36 filters had a mount shaped to accomodate a hood onto them : Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! A36 filters are very easy to find on ebay and dealers... I have a whole set of them... , and the FOOKH too isn't difficult to find (the silver is much more common than the black one, I think) : it is about 18mm long, if I remember correctly... Edited July 16, 2015 by luigi bertolotti 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! A36 filters are very easy to find on ebay and dealers... I have a whole set of them... , and the FOOKH too isn't difficult to find (the silver is much more common than the black one, I think) : it is about 18mm long, if I remember correctly... ' data-webShareUrl='https://www.l-camera-forum.com/topic/247836-filter-fookh-together-on-35-35-summaron/?do=findComment&comment=2855136'>More sharing options...
Tommy Hansen Posted July 16, 2015 Author Share #3 Posted July 16, 2015 (edited) Thank you Luigi! ....another question, as i also have a 50 3.5 Elmar. Do anyone know if it is possible to use the FISON lens hood for both 50 3.5 and Elmar and 35 3.5 Summaron? /Tommy Edited July 16, 2015 by Tommy Hansen Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted July 16, 2015 Share #4 Posted July 16, 2015 (edited) Well... FISON was made for Elmar 50 so in theory it ought to vignette when mounted on a 35... but it does not... I have just made a quick trial with my Summaron A36 with FISON onto, on M240... : no vignetting at all... BUT... after that, I mounted a filter on the Summaron, the FiSON onto the filter, took a shot and.. ZAP !! vignetting in the corners... Edited July 16, 2015 by luigi bertolotti Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted July 16, 2015 Share #5 Posted July 16, 2015 (Quick pic of the above setup... I like to portrait my Summarons... ) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/247836-filter-fookh-together-on-35-35-summaron/?do=findComment&comment=2855533'>More sharing options...
Tommy Hansen Posted July 17, 2015 Author Share #6 Posted July 17, 2015 Hi again Luigi and thank you so much for you help!! Yes it is a nice portrait:) I have some E39 filters already so i think i will go for another solution but it is not 100% Leica... I think i will buy a SOOGZ (silver) and mount one of my E39 filter and then on top of that mount a 15mm deep 39mm screw mount Heliopan lens hood (http://www.bhphotovideo.com/c/product/800619-REG/Heliopan_72019H_39_mm_Metal_Lens.html) (there is also 8mm deep Heliopan hood, just in case..). Hopefully i will be able to post my portrait in a couple of weeks:) /Tommy Quote Link to post Share on other sites More sharing options...
gyoung Posted July 17, 2015 Share #7 Posted July 17, 2015 Advertisement (gone after registration) Soogz are like hens teeth to find and usually go for silly money unfortunately, I looked for a long while to get one to put 39mm filters on my Summaron and Elmars. A set of A36 filters will probably cost a lot less! Gerry Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted July 17, 2015 Share #8 Posted July 17, 2015 (edited) Soogz are like hens teeth to find and usually go for silly money unfortunately, I looked for a long while to get one to put 39mm filters on my Summaron and Elmars. A set of A36 filters will probably cost a lot less! Gerry Luckily I have one... at "M8 - UVIR" times was very useful : now it stays unused... I think that I could renounce to it if some friend here NEEDS it and doesn't find one .. PM me in case... Edited July 17, 2015 by luigi bertolotti Quote Link to post Share on other sites More sharing options...
yashicachris Posted September 14, 2020 Share #9 Posted September 14, 2020 On 7/16/2015 at 2:48 AM, luigi bertolotti said: Yes : I understand that your LTM Summaron is the A36 version : in this case, if you use the standard Leitz A36 clamp-screw filters, you can mount onto them the FOOKH ; is a standard configuration : all the Leitz A36 filters had a mount shaped to accomodate a hood onto them : Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! A36 filters are very easy to find on ebay and dealers... I have a whole set of them... , and the FOOKH too isn't difficult to find (the silver is much more common than the black one, I think) : it is about 18mm long, if I remember correctly... Excellent info. Thanks for posting it! Chris Quote Link to post Share on other sites More sharing options...
romualdo Posted September 15, 2020 Share #10 Posted September 15, 2020 (edited) here's my solution - gone via the SOOGZ path (luckily I found it for a very cheap/reasonable price) The filter screws into the SOOGZ which then attaches over the lens. Quite a number of hoods will fit over & into the SOOGZ groove Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited September 15, 2020 by romualdo 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/247836-filter-fookh-together-on-35-35-summaron/?do=findComment&comment=4046356'>More sharing options...
Matlock Posted September 15, 2020 Share #11 Posted September 15, 2020 Got my SOOGZ in 2009 and it has been put to good use ever since. Quote Link to post Share on other sites More sharing options...
