wattsy Posted June 6, 2016 Share #121 Posted June 6, 2016 Advertisement (gone after registration) I have a black paint 50 Summilux LHSA and the 13206 filter seems to fit fine. Not sure if it is the same as the black chrome 50 Summilux. That's interesting. I would have thought that the lens barrel and hood design is identical between these special editions. I came quite close to buying this lens as the example I tried had a lovely smooth focussing action (which my standard version of the lens bought in 2005 never had, even after many years of use) but the hassle with the hood and filters was a factor in my choosing not to buy. That and insufficient appetite for spending £3000 on new kit. ;-) Quote Link to post Share on other sites More sharing options...
Advertisement Posted June 6, 2016 Posted June 6, 2016 Hi wattsy, Take a look here Hood fitting problem with 50mm SX black chrome (11688). I'm sure you'll find what you were looking for!
jdlaing Posted June 6, 2016 Share #122 Posted June 6, 2016 That's interesting. I would have thought that the lens barrel and hood design is identical between these special editions. I came quite close to buying this lens as the example I tried had a lovely smooth focussing action (which my standard version of the lens bought in 2005 never had, even after many years of use) but the hassle with the hood and filters was a factor in my choosing not to buy. That and insufficient appetite for spending £3000 on new kit. ;-) Could it be the hood recess is the only difference? Or the hood itself? Quote Link to post Share on other sites More sharing options...
jaroopaitummai Posted June 6, 2016 Share #123 Posted June 6, 2016 Just to mention that my 13206 filter is the one that has no front thread. I know that there are 2 versions of this 13206 filter. 1 Quote Link to post Share on other sites More sharing options...
DBAUDUI1 Posted June 16, 2016 Share #124 Posted June 16, 2016 Hello, Did somebody try the filter: 43mm MC UV Filter For Leica Summilux E43? You can find it on ebay: http://www.befr.ebay.be/itm/43mm-MC-UV-Filter-For-Leica-Summilux-E43-/391127097273?hash=item5b10fddfb9:m:mWazNAhiHLR13KJIgwtHJIw Many thanks in advance. Dominique Quote Link to post Share on other sites More sharing options...
DBAUDUI1 Posted July 4, 2016 Share #125 Posted July 4, 2016 Hello, Did anybody try the filter ZEISS Filtre UV T* 43mm? It seems to have a thin metallic ring. Many thanks in advance. Dominique Quote Link to post Share on other sites More sharing options...
ThirtyOne Posted July 9, 2016 Share #126 Posted July 9, 2016 It seems that a new hood would be the only real solution instead of having customers buy a special set of filters solely for use with this lens.... 1 Quote Link to post Share on other sites More sharing options...
otho Posted July 9, 2016 Share #127 Posted July 9, 2016 Advertisement (gone after registration) Hello, Did anybody try the filter ZEISS Filtre UV T* 43mm? It seems to have a thin metallic ring. Many thanks in advance. Dominique I use Zeiss UV T* 49mm on my Zeiss-Sony FE 35 f/2.8 lens (on Sony A7R II body). Filter made in Japan, good quality, but Heliopan SH-PMC UV is even thinnest. Quote Link to post Share on other sites More sharing options...
DBAUDUI1 Posted August 10, 2016 Share #128 Posted August 10, 2016 Hello, I have just tried the BW nano E43 filter on the summilux 35 FLE Black Chrome, and its diameter is too wide to allow to use it together with the sunshade. So it does not work, although the filter fits nicely on the lens.... Lets wait for Leica to provide a new E43 UV filter for this lens and its hood. Best regards. Dominique Quote Link to post Share on other sites More sharing options...
DBAUDUI1 Posted August 25, 2016 Share #129 Posted August 25, 2016 Hello, I am going to try this filter: leica 13206 with a male and a female thread. I will keep you updated. Dominique Quote Link to post Share on other sites More sharing options...
lct Posted August 25, 2016 Share #130 Posted August 25, 2016 Hello, I am going to try this filter: leica 13206 with a male and a female thread. I will keep you updated. Dominique 13206 is M 43 x 0.5 whilst you need an M 43 x 0.75 filter. Quote Link to post Share on other sites More sharing options...
DBAUDUI1 Posted September 5, 2016 Share #131 Posted September 5, 2016 Hello Sir, You are correct, the filter 13206 does not work on the summilux 50 1.4 black Chrome E43 (latest release). You can not screw it on the lens, and even if you could, its diameter is too wide to use it together with the sunshade. I am going to use this lens without any filter... Best regards. Dominique Quote Link to post Share on other sites More sharing options...
jaapv Posted September 5, 2016 Share #132 Posted September 5, 2016 What about a B+W 007 filter in slim mount? At least that is a filter that is designed as a protective filter with less optical impact and tougher glass. IIRC the mount is extra-slim. Quote Link to post Share on other sites More sharing options...
cwcheung Posted October 6, 2016 Share #133 Posted October 6, 2016 Just bought the Cokin Ultra Slim Filter, hope to fix the hood problem. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/245904-hood-fitting-problem-with-50mm-sx-black-chrome-11688/?do=findComment&comment=3124826'>More sharing options...
cwcheung Posted October 7, 2016 Share #134 Posted October 7, 2016 Update: The cokin filter does not work. Quote Link to post Share on other sites More sharing options...
Shlomo Posted February 20, 2017 Share #135 Posted February 20, 2017 Quote Link to post Share on other sites More sharing options...
Shlomo Posted February 20, 2017 Share #136 Posted February 20, 2017 Quote Link to post Share on other sites More sharing options...
Shlomo Posted February 20, 2017 Share #137 Posted February 20, 2017 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/245904-hood-fitting-problem-with-50mm-sx-black-chrome-11688/?do=findComment&comment=3217744'>More sharing options...
Shlomo Posted February 20, 2017 Share #138 Posted February 20, 2017 What is the meaning of this? Quote Link to post Share on other sites More sharing options...
peterjcb Posted March 12, 2017 Share #139 Posted March 12, 2017 just checking in here....from the last post there still doesn't appear to be a solution for using the lens with the lens shade and a filter...am I correct? Quote Link to post Share on other sites More sharing options...
lct Posted March 12, 2017 Share #140 Posted March 12, 2017 The 13417 filter should fit (see post # 21 above) but i have no experience with this lens. Quote Link to post Share on other sites More sharing options...
