leica1215 Posted April 27, 2015 Share #1 Posted April 27, 2015 Advertisement (gone after registration) I browsing through the menu, found that color profile can be either one, which one you use? my two questions in one tread, which focus mode you using I am using spyder pro to adjust my monitor color. Thanks Quote Link to post Share on other sites More sharing options...
Advertisement Posted April 27, 2015 Posted April 27, 2015 Hi leica1215, Take a look here RGB color or Adobe RGB? spot, or center weight focus?. I'm sure you'll find what you were looking for!
CheshireCat Posted April 27, 2015 Share #2 Posted April 27, 2015 I browsing through the menu, found that color profile can be either one, which one you use? my two questions in one tread, which focus mode you using I am using spyder pro to adjust my monitor color. Thanks This setting only applies to JPEG files. You can ignore it if you only shoot RAW. The Adobe RGB color space has a wider color gamut than sRGB, hence better colors. But the problem is some software (including some web browsers) expects sRGB and incorrectly displays Adobe RGB. On Internet sites, sRGB is more compatible, at the cost of worse colors (but it really depends on the photo) on the wide color gamut displays every serious photographer should use. 2 Quote Link to post Share on other sites More sharing options...
mjh Posted April 27, 2015 Share #3 Posted April 27, 2015 (edited) If you need to ask, choose sRGB. Both colour spaces contain the same number of colours, just not the same colours. There are some hues of green and blue that fall within the Adobe RGB gamut but cannot be captured exactly in an sRGB colour space. On the other hand, within its gamut sRGB has slightly finer distinctions between hues. If you care a lot about colour rendition you would use a raw workflow in which case the camera’s colour space setting was immaterial anyway. Edited April 27, 2015 by mjh 2 Quote Link to post Share on other sites More sharing options...
CheshireCat Posted April 28, 2015 Share #4 Posted April 28, 2015 On the other hand, within its gamut sRGB has slightly finer distinctions between hues. These finer distinctions are not visible in normal photography, due to sensor noise naturally dithering the image. Quote Link to post Share on other sites More sharing options...
jaapv Posted April 28, 2015 Share #5 Posted April 28, 2015 Most monitors are not able to render Adobe RGB. Use Adobe RGB only if you have a fully colour managed workflow. If you shoot raw and use Lightroom the question does not arise. Quote Link to post Share on other sites More sharing options...
tobey bilek Posted April 29, 2015 Share #6 Posted April 29, 2015 For a color managed work flow, raw wins . Color space makes no difference. If not color managed, sRGB and JPEG . Lightroom and PS/ACR will show out of gamut colors and it is up to you to correct them. Video on Adobe TV. Quote Link to post Share on other sites More sharing options...
CheshireCat Posted April 29, 2015 Share #7 Posted April 29, 2015 Advertisement (gone after registration) For a color managed work flow, raw wins . Color space makes no difference. If not color managed, sRGB and JPEG . Everything will be color managed in the near future, therefore shooting sRGB JPEG is not a wise choice (and has several other downsides due to JPEG compression). If needed, a raw image can be converted to sRGB JPEG in a couple seconds. The classical use-case is images for a web site, for which you need to resize and save a copy of the image; therefore the colorspace castration step is "free". Quote Link to post Share on other sites More sharing options...
leica1215 Posted April 29, 2015 Author Share #8 Posted April 29, 2015 Thanks for all your kind reply, I always find great opinion and learn new tips in the forum.. Cheers Quote Link to post Share on other sites More sharing options...
chris_tribble Posted April 30, 2015 Share #9 Posted April 30, 2015 You also asked about spot vs centre weighted, but you described these as focusing modes. In fact they're METERING modes (in the ADVANCED as opposed to the CLASSIC mode). I've found that it's usually better (the camera is more responsive) to stick with CLASSIC metering. The only times I've used advanced have been for very difficult light conditions, when the spot mode has been useful, FOCUS options are either to use the Range Finder (BEST for almost all purposes) or to use Contrast Detection when using the EVF. Hope this helps Best 1 Quote Link to post Share on other sites More sharing options...
