SEOOM & SEEOF
Hello,
Let me introduce them to you...both are Summicron 2/90 Made in Canada,
they are from the same year :1960, both were screw mount born but, the first was M mount and red dot added and it is on a M3 from 1955 the second remained genuine and it is on a IIIg from 1957.
just wanted to share with you
Thanks for looking
Usefull for Visoflex, is´nt it?
Absolutely
To complement JC display of two slightly different Summicrons 90 of the same year... here are two slightly different Summicrons 90 of very different years... :) : the black one (2814779 - number is on side) is from the "spurious" preliminary batch dated 1977 (before official intro) with its distinctive design "error-naivety" (the shade covers the f stop ring, and pretending to declare a DOF at f2 is practically unuseful) , the other is from the last year of production (1995) - maybe from the last batch which included silver items. Both from Canada, though in 1995 the Elcan factory didn't belong anymore to Leica.
There is an additional variation of the type IB 90mm Summicron in the 1818xxx range. The minimum aperture of the lens is f/16 but the depth of field indicator extends to f/22.
When using the lens head on the Visoflex II or III there is a choice of two short barrels or focussing mounts. Probably the most common is the focussing mount ZOOEP/16463, scaled from 1m to imfinity. There is also the focussing mount 16462 which additionally takes the lens head of the 135mm f/2.8 Elmarit. A half-hearted attempt to purchase the latter lens (first design) was aborted when its lens head failed to fit my ZOOEP or its extension tube OUEPO/16474 when used in conjunction with ZOOEP.
  • 4 weeks later...
Hello Orient XL,
 The lens in your Post #7 above is actually a Second Version 90mm Summicron. Some Second Version 90mm Summicrons only stopped down to F16. Others to F22. The lenses shown in Luigi's Post #6 above are actually the Third Version.
It is possible that what you showed in the photographs was a lens head matched to a later acquired focussing mount. Did you ever notice if the serial number of the lens head matched the serial number of the focussing mount?
Since the focussing mount & the lens head did fit together correctly it is probably possible to find a usable focussing Short Mount. If you look elsewhere in this section you will see a similar problem & efforts for its solution with a Third Version F4.8, 280mm Visoflex Lens.
 Bellows II,16598J ............ is its title.
Hello Jean Claude,
Would you also by any chance have a later version black 11126/11132?  If so: Is it black paint or anodized? Knurled dimples or just knurled? Or is a later version black 11126/11132 like a screwmount 35mm Summilux: Something which should exist but nobody seems to have 1.
Best Regards Both,
Michael
Hello Jean Claude,
Best Regards ,
Michael
you mean black in screw mount ?  Lager says to have seen 3 of them... :huh:  (1680297 1680310, 1680353, this one depicted in his book) : painted, it looks... and Lager says they were "on request"...
Hello Luigi,
Sorry for the confusion. What I was asking about was whether Jean Claude might have a picture of a later version Black Short Mount Pre-Set 90mm Summicron lens (11126) or a later version Black Pre-Set lens head alone (11132) for bellows mounting.
The question about the 35mm Screw Mount Summilux was used as a comparative example.
Best Regards,
Michael
Michael,
My 90mm Summicron is definitely the first version with 6 lens elements. I designated it as version IB to distinguish it from the very earliest type (IA) with the detachable hood. Further, the serial number quoted 1818xxx is from 1960 a full 20 years before the second version appeared.
Hello Orient XL,
I was thinking of the version with the NON detachable lens head as Version 1 followed by the same 6 element optical system with a detachable lens head as Version 2. This would make the shorter & lighter next optical configuration Version 3.
Best Regards,
Michael.
