Echo63 Posted May 23, 2016 Share #21 Posted May 23, 2016 (edited) Advertisement (gone after registration) I've never seen any flashes which are voltage controlled. Do you know of any?most studio flashes use either voltage control or capacitor switching (or a combination of both)The Alien Bees and White lightnings are voltage controlled. Pretty sure the Bowens and Elinchrom units i have used are. And the old Courtney units at a previous job were capacitor switched. Theres a good bit of info about flash duration here https://www.paulcbuff.com/sfe-flashduration.php Edited May 23, 2016 by Echo63 Quote Link to post Share on other sites More sharing options...
Advertisement Posted May 23, 2016 Posted May 23, 2016 Hi Echo63, Take a look here advantage of leaf shutter in x series cameras?. I'm sure you'll find what you were looking for!
TMorita Posted May 24, 2016 Share #22 Posted May 24, 2016 Yah, I'm already knowledgeable about t.1 and t.5 times because I do a lot of shooting at high shutter speeds The main problem with shooting outdoors is not the t.1/t.5 time based on my experience. The main problem is the radio trigger latency. Some radio triggers have very high latency, on the order of 1 msec or more. The better ones have a fairly low latency, around 300 usec or so. Toshi 1 Quote Link to post Share on other sites More sharing options...
Echo63 Posted May 24, 2016 Share #23 Posted May 24, 2016 when you are working right on the edge - nothing beats a wire i haven't had any issues with my Pocket Wizards up the highest shutter speeds i have tested - 1/1000 on my X100, and 1/2000 on my 1Dmk1 (which has a neat trick, the mechanical shutter stops at 1/500th and shutter speeds are generated electronically from there, a trick i wish they had continued on the newer models) using a mix of TT1 and Multimax transmitters, and TT5 and Multimax Receivers with Canon 580EX and 580EX2 speedlights Quote Link to post Share on other sites More sharing options...
