The Leica Forum uses cookies. Read the privacy statement for more info. To remove this message, please click the button to the right:    OK, understood.
M Monochrom, filters and Silver Efex Pro 2
monochrom
  • Please log in to reply
63 replies to this topic
#1 ymc226
ymc226
    Erfahrener Benutzer
  • Members
  • 197 posts
Posted 31 August 2012 - 11:55
Advertisement (Gone after free registration)
A question for the lucky owners who already have their M Monochrom.
I'm going through my B&W filter inventory to see if I need to add but would like to know if it is better to shoot with the yellow or red filter or just process in SEP2 using no filter?
I believe it would be easier to add rather then remove contrast in post processing but please give me your opinions on the pros and cons of either method.
#2 jaapv
jaapv
    Moderator
  • Moderators
  • 45,674 posts
  • LocationBehind a Red Dot
  • City / Ort:Hellevoetsluis
Posted 31 August 2012 - 16:10
As you cannot adjust color channels, the only way to influence the tonal response of the camera is a filter, just like in film days.
  • sydkugelmass said thank you to this
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Posts in blue bold font are made as a moderator
Leica user since 1976
I like taking pictures of Dogs because the don't object to being photographed - and they don't ask for prints.
Elliot Erwitt
#3 ymc226
ymc226
    Erfahrener Benutzer
  • Members
  • 197 posts
Posted 31 August 2012 - 17:22
Thanks Jaapv.
I guess the contrast sliders on SEP2 are useless but I assume that since Leica provides the software, other functions such as exposure/brightness, either local or generalized effects still are possible.
That means I need filters for all of the lenses I would use the Monochrom with.
#4 pico
pico
    Sponsoring Canine
  • Premium Member
  • 13,688 posts
  • LocationMinnesota
  • City / Ort:Winona
Posted 31 August 2012 - 17:48
I'm going through my B&W filter inventory to see if I need to add but would like to know if it is better to shoot with the yellow or red filter [...]
It is not really a question of either/or but to know when to use which. In my experience a red filter is just horrible. Too much contrast, and focus is degraded. And don't forget a blue filter for those circumstances that are largely shadow, no sky. Experiment to learn and be happy!
#5 SpiritShooter
SpiritShooter
    Erfahrener Benutzer
  • Members
  • 108 posts
  • City / Ort:Florida
Posted 31 August 2012 - 17:50
Contrast, brightness, exposure, clarity, sharpening all work. And, you can do all or the normal local adjustments you would do in LR or Photoshop.
Imagine if you had scanned a b/w film negative and proceeded to work on it in Photoshop. Pretty much the same process.
For reference:
A yellow or, more dramatically, orange or red, filter will enhance the contrast between clouds and sky by darkening the blue sky. A deep green filter will also darken the sky, and additionally lighten green foliage, making it stand out against the sky. A blue filter mimics the effect of older orthochromatic film, or even older film sensitive only to blue light, rendering blue as light and red and green as dark, showing blue skies as overcast with no contrast between sky and clouds, darkening blond hair, making blue eyes nearly white and red lips nearly black.
Not sure why a red filter is "horrible". I have used red and even dark red to increase contrast for certain images and results. In fact, if you look at the images on my website, the majority of the film images were shot with either light red or red filtration. The digital conversions were almost all done with varying levels of orange or red filtration.
Edited by SpiritShooter, 31 August 2012 - 18:02.
  • johnbuckley and algrove said thank you to this
#6 johnbuckley
johnbuckley
    Erfahrener Benutzer
  • Premium Member
  • 1,431 posts
  • LocationWashington, DC; Jackson, WY
  • City / Ort:Washington, D.C.
Posted 31 August 2012 - 18:50
I've been experimenting with yellow and orange filters, and may not have a sophisticated enough viewpoint, but the orange filter sure did seem to work well on a very bright mid-afternoon. Nothng I shot was overexposed, and did I mention it was bright?
http://www.tulipfrenzyphotography.com
For M10 Images Of Washington Demonstrations In The Age Of Trump:
http://www.tulipfren.../new-gallery-2/
#7 ymc226
ymc226
    Erfahrener Benutzer
  • Members
  • 197 posts
Posted 31 August 2012 - 18:55
I don't have any experience with scanning, only film and just into digital. If I understand Jaapv correctly, there is not much that can be done tonally with contrast with Monochrom DNGs but you seem to state that contrast can be changed to a certain extent. I hope this is true. Thus, my understanding is that most of the tone adjustment should be done with optical filters but some degree of final adjustment can be done with LR or SEP2.
#8 jaapv
jaapv
    Moderator
  • Moderators
  • 45,674 posts
Posted 31 August 2012 - 19:43
Tonal response is not the same as contrast. Tonal response determines the shade of gray (relatively) that is assigned to a specific color. Contrast is the amount of difference between the shades of gray. The latter can be controlled in postprocessing, the former not.
i.e if a specific green object has been assigned a shade of grey and a specific red object is rendered the same shade of gray, no amount of contrast enhancing will differentiate the objects. However, if you use a green or red filter, the green and the red object will have different grey shades, and now you can boost the contrast between the two.
  • algrove said thank you to this
Jaap
Elliot Erwitt
#9 SpiritShooter
SpiritShooter
    Erfahrener Benutzer
  • Members
  • 108 posts
Posted 31 August 2012 - 20:22
Exactly,
And, by using careful post production selections one can in fact isolate individual elements within the image and vary the "shade of gray". Guess it depends on how much post production wizardry one wishes to engage in.
#10 ymc226
ymc226
    Erfahrener Benutzer
  • Members
  • 197 posts
Posted 31 August 2012 - 20:47
Thanks for the clarification. That makes more sense.
#11 chris_tribble
chris_tribble
    Erfahrener Benutzer
  • Premium Member
  • 4,010 posts
  • LocationLondon / Kendal
  • City / Ort:London / Kendal
Posted 01 September 2012 - 18:46
excuse my ignorance here - but are we saying that with the MM we'll have to use coloured filters to achieve certain effects, and that this can't be done with something like Silver Efex? I can understand the need for ND filters with fast lenses given the shift to ISO 320 base, but wouldn't relish going back to colour filters in order to enhance skies etc.
Grateful for any comments from those with practical MM experience.
Thanks.
#12 C_R
C_R
    Erfahrener Benutzer
  • Members
  • 198 posts
Posted 01 September 2012 - 19:24
Still waiting for my MM. But Sean Reid showed nicely the effect of different filters with MM. For example, you will never get the effect of a yellow-green filter on foliage with SFEX. Impossible.
Carsten
#13 pico
pico
    Sponsoring Canine
  • Premium Member
  • 13,688 posts
  • LocationMinnesota
  • City / Ort:Winona
Posted 01 September 2012 - 19:30
To manipulate color rendering you must use color filters, just as in B&W film.
What other effects are you considering?
#14 lct
lct
    Ex-Newbie
  • Members
  • 14,935 posts
Posted 01 September 2012 - 20:02
No comment from me sorry as i will not purchase the MM for this very reason. I feel much more comfortable with the digital filters of Silver Efex so M10 perhaps but MM is a no no. My feeling is that most of those who're claiming that they will use optical colored filters might well end up using no filter at all or a couple of yellow ones just in case. But i may be wrong of course. :rolleyes: :D
#15 pedaes
pedaes
    Sponsoring Member
  • Premium Member
  • 713 posts
  • City / Ort:Ferndown UK
Posted 01 September 2012 - 20:07
Interesting to speculate which would make the best final print -MM with one guess at which filter to use or M9 and all the options to try in post-processing. Discuss.
#16 pop
pop
    Moderator
  • Moderators
  • 18,682 posts
  • Locationnear Basel
Posted 01 September 2012 - 20:12
If you have to guess, you'd better use the M9, unless you are willing to learn. There are, however, people who don't have to guess.
  • jaapv said thank you to this
Philipp
Beiträge in dieser blauen Schrift schreibe ich als Moderator. --
I use this blue typeface when I write in my function as a moderator.
#17 pedaes
pedaes
    Sponsoring Member
  • Premium Member
  • 713 posts
Posted 01 September 2012 - 21:24
Ah - the man who's judgement is not a guess. Think I know him..
  • andkeen said thank you to this
#18 chris_tribble
chris_tribble
    Erfahrener Benutzer
  • Premium Member
  • 4,010 posts
Posted 02 September 2012 - 08:29
:D
#19 ymc226
ymc226
    Erfahrener Benutzer
  • Members
  • 197 posts
Posted 02 September 2012 - 16:07
Another question for filter users, specifically the darker orange and red filters. These usually specify 2 and 3 extra stops of exposure respectively by the manufacturer.
For MM or B&W film M users of the M6 TTL, M7 or MP, does TTL metering more or less accurately increase exposure by the predicted amount when the camera is set to aperture priority? If not, how much "corrected" underexposure is there present for the orange and red filter respectively?
#20 esquire53
esquire53
    Erfahrener Benutzer
  • Members
  • 1,445 posts
  • LocationParis
  • City / Ort:Paris
Posted 02 September 2012 - 16:20
for the film ones, yes, it does.
MM I assume it will be the different for red filter, from what I read so far
Also tagged with one or more of these keywords: monochrom
0 user(s) are reading this topic
