jaapv Posted July 28, 2012 Share #21 Posted July 28, 2012 Advertisement (gone after registration) Here’s a tip for anyone who doesn’t want file numbering to be reset. This firmware update process will reset file numbering. If you want to preserve your existing file number sequence, put aside a card with photos on it taken immediately before you update. Perform the update and re-insert the card you laid aside. When you start shooting again the camera should start its numbering where it left off, giving you an uninterrupted sequence of file numbers. Added to M9 FAQ Quote Link to post Share on other sites More sharing options...
Advertisement Posted July 28, 2012 Posted July 28, 2012 Hi jaapv, Take a look here Instructions for updating LEICA camera Firmware. I'm sure you'll find what you were looking for!
businessasusual Posted September 22, 2012 Share #22 Posted September 22, 2012 Quick question - I am one upgrade behind (held off after reading about bugs). When the next upgrade is released - can I jump from this to next and skip the in between upgrade? Thanks. Quote Link to post Share on other sites More sharing options...
andybarton Posted September 22, 2012 Author Share #23 Posted September 22, 2012 Yes. 1 Quote Link to post Share on other sites More sharing options...
Guest Gilgamesh Posted June 11, 2013 Share #24 Posted June 11, 2013 Instructions for updating the LEICA M (Typ 240) Firmware 1. Format an SD memory card in your LEICA M. 2. Turn off the camera and insert the card into an SD card reader – either integrated or connected to your computer. (A reader is required for Firmware updates). 3. Download the Firmware file from the Leica M site using the “UPDATES” link. 4. Save the file FW_M240_1_1_0_2.FW at the top level of the card’s folder structure. 5. Remove the card properly from your card reader, insert the card into the camera and close the bottom cover. 6. Press the “INFO” button and hold it, simultaneously turn on the camera using the main switch. 7. The update process takes several 2-4 minutes. “Loading file...” appears on the screen. 8. When the update is done, a corresponding message appears on the screen. The Message disappears after some seconds. Note: • If the battery does not have sufficient charge, you will see a corresponding warning message. This is what the Leica site says as of 11 June 2013. It calls it an "FW"file as in - FW_M240_1_1_0_2.FW Quote Link to post Share on other sites More sharing options...
lenticularis Posted July 15, 2013 Share #25 Posted July 15, 2013 HELP! I bought an M9, received today from overseas, that has the latest 1.196 firmware, but as reported by the seller, will not recognise the SD card at all. I have an M8 and formatted an SD card and then copied the 1.196.upd file to the root directory. I had hoped this might enable me to try and re-install the M9 firmware (on my new M9 of course). No success however. Can someone please share a previous version of the M9 firmware with me, via a Dropbox link or whatever? I want to try a re-install again with that older version. I have tried using both a Sandisk 8GB card and another brand. Of course it may be that formatting the card on the M8 will not work in any case. thanks in advance, David Quote Link to post Share on other sites More sharing options...
jaapv Posted July 15, 2013 Share #26 Posted July 15, 2013 (edited) That is why we have a FAQ...: http://www.l-camera-forum.com/leica-forum/leica-m9-forum/130720-leica-m8-m8-2-m9-m9p-2.html#post2285118 But - the M8 cards do not work well with the M9. Get a new, unused card and stick that one in the M9. Note - SD or SDHC ONLY! If the camera does not recognise the card, it cannot install the firmware anyway. Edited July 15, 2013 by jaapv Quote Link to post Share on other sites More sharing options...
Adrian Lord Posted July 30, 2013 Share #27 Posted July 30, 2013 Advertisement (gone after registration) Sorry more issues: please assist! I am trying to update my new MM to the latest firmware. The downloaded update zip is: Mm-1_002.upm file. Trouble is the MB pro wont recognise .upm and unzip it. Neither will an app I just paid to downloaded from app store. I am probably being stupid... Adrian Quote Link to post Share on other sites More sharing options...
andybarton Posted July 30, 2013 Author Share #28 Posted July 30, 2013 The upm file is already unzipped. Just put that in the root if your SD card and follow the instruction. 1 Quote Link to post Share on other sites More sharing options...
Adrian Lord Posted July 30, 2013 Share #29 Posted July 30, 2013 Thank you Andy - I was being stupid!!!! 1 Quote Link to post Share on other sites More sharing options...
readypat Posted December 15, 2013 Share #30 Posted December 15, 2013 Your instructions were very helpful, especially where the pictures were included. This process was very frustrating and if I had not had your blog this update would not have happened. I went fom1.176 to 1.196, I had to overwrite the card and take the actual update download to my desktop and copy to the card. Trying to put the file directly to the card would not allow it work. I tried it 10 times, before figuring out that I could not load it directly to the card. I have WindowsXP. Not sure if that has anything to do with it. Thank you. Quote Link to post Share on other sites More sharing options...
andybarton Posted December 15, 2013 Author Share #31 Posted December 15, 2013 No, thank you. 1 Quote Link to post Share on other sites More sharing options...
Guest Posted May 11, 2014 Share #32 Posted May 11, 2014 This is the clearest and best written instructions I have seen for a long time on such subject for any camera I have used. So well done. Quote Link to post Share on other sites More sharing options...
cherzeca Posted June 30, 2014 Share #33 Posted June 30, 2014 latest firmware (27/6/14) doesn't unzip after i download. appears to be a .FW file that my mac doesn't know what app to use to open with...and neither do i Quote Link to post Share on other sites More sharing options...
cherzeca Posted June 30, 2014 Share #34 Posted June 30, 2014 downloaded firmware latest firmware update onto card and it says it is a unix executable file. what's up with that? Quote Link to post Share on other sites More sharing options...
andybarton Posted June 30, 2014 Author Share #35 Posted June 30, 2014 It would appear that the file that you download from Leica to update the M240 is the firmware itself. (Someone who owns the camera will confirm, I am sure - I don't) It's not a zipped file (as other firmwares have been) As I have said above, your Mac (or a PC) cannot use this file and it will not do anything on your computer. Just drag the file to the root of a newly formated SD card, and follow the instructions for updating. Quote Link to post Share on other sites More sharing options...
pico Posted June 30, 2014 Share #36 Posted June 30, 2014 Just drag the file to the root of a newly formated SD card, and follow the instructions for updating. See what happens when Leica makes it simple! People presume it must be complex. [emoji21] Quote Link to post Share on other sites More sharing options...
pop Posted July 1, 2014 Share #37 Posted July 1, 2014 The downloaded file has the extension ".FW" and not ZIP, both on my MAC and my Android tablet, and "weighs" 9.5MB. This contradicts what they say on the Leica site, where they said it was a ZIP file of that size. At first I thought my MAC was unzipping the ZIP file without being asked to, but it's quite the same on Android and the file size most likely would be different if that was the case. 1 Quote Link to post Share on other sites More sharing options...
cherzeca Posted July 1, 2014 Share #38 Posted July 1, 2014 i agree with pop's comment, as you can see by my two earlier comments. leica screwed up this update. can someone moderating this board tell leica to fix? thanks Quote Link to post Share on other sites More sharing options...
andybarton Posted July 1, 2014 Author Share #39 Posted July 1, 2014 Leica haven't screwed the update. Quote Link to post Share on other sites More sharing options...
pico Posted July 1, 2014 Share #40 Posted July 1, 2014 downloaded firmware latest firmware update onto card and it says it is a unix executable file. what's up with that? That isn't Leica's fault. Your computer just does the best it can to identify it. Just follow the installation directions and all will be good. 1 Quote Link to post Share on other sites More sharing options...
