The Leica Forum uses cookies. Read the privacy statement for more info. To remove this message, please click the button to the right:    OK, understood.
* * * * * 1 votes
OUFRO 16469Y 16469 Differences
  • Please log in to reply
16 replies to this topic
#1 k-hawinkler
k-hawinkler
    Erfahrener Benutzer
  • Members
  • 9,181 posts
  • City / Ort:The "Land of Enchantment"
Posted 10 May 2011 - 06:38
Advertisement (Gone after free registration)
OUFRO : Large Knob : Large Red Pin : Ernst Leitz Wetzlar Germany
16469Y : Small Knob : Large Red Pin : Ernst Leitz Wetzlar Germany
16469 : Small Knob : Small Red Pin : Leitz Wetzlar Germany
Attached File  2011-05-09_22-29-05-•-M9-Viso_III-65mm-f3.jpg   237.03KB   663 downloads
M9 + Visoflex III + Elmar 65/3.5
Provided these are indeed original items, when were the different versions made?
Best, K-H.
  • Pecole and JMF said thank you to this
#2 luigi bertolotti
luigi bertolotti
    Erfahrener Benutzer
  • Members
  • 11,122 posts
  • City / Ort:Brescia
Posted 10 May 2011 - 07:35
A fine multistrate extension tube...:)... I think in the right time order - oldest at the top and all the weight on the shoulders of the youngest :P : I am not 100% sure, but by logic the 5 letters code were the first, then the 5 digits with letter (whose significance, btw, has been always unclear to me... I have never seen 2 identical set of digits with a different letter), then the "modern" (still used) 5 digits-only code... imho, the obliteration of the name "Ernst" is also a sign of a later build.
Edited by luigi bertolotti, 10 May 2011 - 07:38.
  • k-hawinkler said thank you to this
#3 k-hawinkler
k-hawinkler
    Erfahrener Benutzer
  • Members
  • 9,181 posts
Posted 12 May 2011 - 13:21
Luigi,
You are quite right. That's how I sometimes use them.
Attached File  DSC_2633.jpg   295.53KB   619 downloads
Here coupled with some Kenko extension tubes for Nikon mounts and Leica to Nikon and Nikon to Leica adapters on M9, Viso, and 400/5.6.
Some images obtained with this rig:
Attached File  2011-05-10_10-23-03 • M9 Viso III extension rings 400mm f5.6 - Bees_00_small.jpg   294.7KB   622 downloads
Attached File  2011-05-10_10-39-43 • M9 Viso III extension rings 400mm f5.6 - Bees_00_small.jpg   284.24KB   601 downloads
Attached File  2011-05-10_10-49-52 • M9 Viso III extension rings 400mm f5.6 - Bees_00_small.jpg   293.85KB   594 downloads
Attached File  2011-05-10_09-40-54 • M9 Viso III extension rings 400mm f5.6 - Bees_00_small.jpg   287.21KB   599 downloads
A couple more images are posted here: http://www.l-camera-...t-3-images.html
Bees need water too.
Best, K-H.
  • luigi bertolotti, mmx_2, Pecole and 6 others said thank you
#4 jc_braconi
jc_braconi
    Moderator
  • Moderators
  • 4,509 posts
Posted 12 May 2011 - 18:53
Impressive results ! Congratulations !
Best regards
JCBraconi
Leica Ambassador
LEICA HISTORICA web site
jc_braconi @ LFI Gallery
#5 k-hawinkler
k-hawinkler
    Erfahrener Benutzer
  • Members
  • 9,181 posts
Posted 13 May 2011 - 04:23
JC,
Thank you, K-H.
#6 Dao De Leitz
Dao De Leitz
    " Herr_der_Ringe Lord_of_the_Rings "
  • Members
  • 919 posts
  • City / Ort:Pfälzerwald / Palatinate Forest
Posted 28 August 2011 - 21:49
Hello K-H.,
thank you for the pictures of the stacked rings and the bees.
The rings have a small shift in the position of the locking mechanism.
Does somebody now the reason why the rings have a misalignment of about 0.5mm / circa ~1.5° in the same direction?
Greeting Thorsten
Edited by Dao De Leitz, 28 August 2011 - 22:41.
___
#7 luigi bertolotti
luigi bertolotti
    Erfahrener Benutzer
  • Members
  • 11,122 posts
Posted 28 August 2011 - 22:02
Hello K-H.,
Does somebody now the reason why the rings have a misalignment of about 0.5mm / circa ~1.5° ?
Greeting Thorsten
I'm not sure is like you say... can be a "taking effect"... imho, if one takes a precisely composed picture (stacked knobs along the vertical axis of the frame, center of the frame at 1/2 of the height of the stack) they probably result perfectly aligned... the tolerancing of the bayonet engagement must be very strict... of course, is not like this for the position of the red dot, which can have a rather rough tolerancing.
#8 Dao De Leitz
Dao De Leitz
  • Members
  • 919 posts
Posted 28 August 2011 - 22:33
[FONT="]Thank you L.B.,
my first thoughts were the same - but my small stack is rotating the lock a little.
Greeting Thorsten
[/FONT]
Edited by Dao De Leitz, 28 August 2011 - 22:59.
#9 k-hawinkler
k-hawinkler
    Erfahrener Benutzer
  • Members
  • 9,181 posts
Posted 28 August 2011 - 22:44
Well I have stacked up my 10 rings, namely 3 OUFRO, 5 16469Y, and 2 16469.
The only rings that stack up without a shift are the two 16469. :)
The other eight seem to be shifted by about the same amount and line up at a slight angle with little variation.
One of the 16469Y rings seems to be shifted hardly at all.
Of course, there is some play.
However, even if I force the rings to line up as much as possible the slight shift remains. :eek:
Could it just be a slight misalignment in the manufacturing setup from batch to batch?
Funny but unimportant in using the rings. :D
K-H.
#10 k-hawinkler
k-hawinkler
    Erfahrener Benutzer
  • Members
  • 9,181 posts
Posted 28 August 2011 - 22:50
[FONT="][FONT=Arial]Thank you L.B.,
my first thoughts were the same - but my stack is rotating the lock a little.
Greeting Thorsten
[/FONT]
[/FONT]
The lock, red markers, and engravings seem to rotate just a little bit.
K-H.
#11 Dao De Leitz
Dao De Leitz
  • Members
  • 919 posts
Posted 28 August 2011 - 22:54
... Funny but unimportant in using the rings. :D ...
This is what I wanted to proof. Thanks! ;)
Greeting Thorsten
#12 luigi bertolotti
luigi bertolotti
    Erfahrener Benutzer
  • Members
  • 11,122 posts
Posted 28 August 2011 - 23:32
Well... indeed, thinking well of it, my considerations about tolerancing were not 100% correct... :o: strict tolerancing is needed in the angular positioning of the slot towards the male bayonet (bottom part of the ring) and, same way, the knob towards the female bayonet (top part of the ring) , but the two parts, in itselves, can afford a certain misalignement of some degree, one to each other: as noted above, this does not compromise the functionality of the device... the only inconvenient with a std. lens mounted onto is to have, say, the focus datum line not exactly at 12 o'clock... minor issue.
Edited by luigi bertolotti, 28 August 2011 - 23:36.
#13 ellisson
ellisson
    Member
  • Members
  • PipPip
  • 14 posts
Posted 28 November 2016 - 02:14
How much closer (or magnification) do you get with a single OUFRO ring?  Does one ring buy any macro effect, say with a 75mm summicron?  Does one need to stack multiple rings for a significant macro function?
Thanks,
Gary
#14 jankap
jankap
    Erfahrener Benutzer
  • Premium Member
  • 916 posts
  • City / Ort:Franken
Posted 28 November 2016 - 09:56
To achieve a 1:1 magnification with a 75mm lens (set on infinity) you need a 75mm extension.
One ring will not help very much.
Jan
Edited by jankap, 28 November 2016 - 09:58.
#15 jankap
jankap
    Erfahrener Benutzer
  • Premium Member
  • 916 posts
Posted 28 November 2016 - 11:41
An OUFRO is 10mm thick. So with this extension you can reach a distance of about 350 to 600 mm with a 75mm lens.
Jan
#16 John McMaster
John McMaster
    Erfahrener Benutzer
  • Members
  • 631 posts
  • City / Ort:Occitanie
Posted 28 November 2016 - 12:26
Thanks,
Gary
Probably better off with the newer Macro-Adapter-M which can vary between 18mm and 30mm
http://en.leica-came...Macro-adapter-M
john
#17 luigi bertolotti
luigi bertolotti
    Erfahrener Benutzer
  • Members
  • 11,122 posts
Posted 28 November 2016 - 14:44
john
Surely... and for about 1/3 of its price one can buy the Novoflex LEM/VIS-II... not continuous variation like the Leica Macro Adapter (is a set of rings), but well made, functional, and even with a plus of its own (the full set of rings has a length equal to the Visoflex II/III)
0 user(s) are reading this topic
