Guest Posted July 13, 2014 Share #1 Posted July 13, 2014 Advertisement (gone after registration) Is anyone else having Auto White Balance problems with their T? I upgraded from an X Vario and I have been less than impressed with the T's output, comparatively. The colors and skin tones are just not right. While images are very sharp, they have lacked that warm and special Leica look that the XV had in spades. I shoot in Std mode. I have narrowed it down to the auto white balance being off - seems to consistently run on the cool side (both indoors & outdoors). Images become *much* improved with post processing by tweaking temperature, but I really wasn't expecting to tweak every image to this degree in post. This was not the case with the XV, which had the best OOC colors and skin tones I've ever seen. I know this is supposed to be a strength of the XV and T. Perhaps it's a limited problem with my particular camera. Seems to be a similar situation with the 23mm lens and the zoom for me. I would appreciate any input or advice you all may have. Many thanks! Quote Link to post Share on other sites More sharing options...
Advertisement Posted July 13, 2014 Posted July 13, 2014 Hi Guest, Take a look here Auto White Balance. I'm sure you'll find what you were looking for!
vikasmg Posted July 14, 2014 Share #2 Posted July 14, 2014 Is anyone else having Auto White Balance problems with their T? I upgraded from an X Vario and I have been less than impressed with the T's output, comparatively. ... Perhaps it's a limited problem with my particular camera. Seems to be a similar situation with the 23mm lens and the zoom for me. I would appreciate any input or advice you all may have. Many thanks! That's surprising. White balance is an area where I have had almost no problems. For the most part, under a variety of conditions the camera judges the light Colour just right. I think others in this forum have had the same positive experience. Could be your particular piece as you say. - Vikas 1 Quote Link to post Share on other sites More sharing options...
felixthecat Posted July 14, 2014 Share #3 Posted July 14, 2014 WB is good for my T. Quote Link to post Share on other sites More sharing options...
barjohn Posted July 14, 2014 Share #4 Posted July 14, 2014 I owned the XV and own a T and the T's WB is better as are skin tones. This matches up with various reviewers that have measured its color accuracy and found it to be among the most accurate color rendering cameras. However, that is with RAW. With JPGs, Leica still seems to be all over the map and the XV and the T render JPGs very differently. Quote Link to post Share on other sites More sharing options...
vikasmg Posted July 14, 2014 Share #5 Posted July 14, 2014 That might be the explanation - I've been working exclusively in RAW. Quote Link to post Share on other sites More sharing options...
Joe Lazio Posted July 14, 2014 Share #6 Posted July 14, 2014 Is anyone else having Auto White Balance problems with their T? I upgraded from an X Vario and I have been less than impressed with the T's output, comparatively. The colors and skin tones are just not right. While images are very sharp, they have lacked that warm and special Leica look that the XV had in spades. I shoot in Std mode. I have narrowed it down to the auto white balance being off - seems to consistently run on the cool side (both indoors & outdoors). Images become *much* improved with post processing by tweaking temperature, but I really wasn't expecting to tweak every image to this degree in post. This was not the case with the XV, which had the best OOC colors and skin tones I've ever seen. I know this is supposed to be a strength of the XV and T. Perhaps it's a limited problem with my particular camera. Seems to be a similar situation with the 23mm lens and the zoom for me. I would appreciate any input or advice you all may have. Many thanks! I have a similar problem and many times I set the WB manually:( Quote Link to post Share on other sites More sharing options...
thighslapper Posted July 14, 2014 Share #7 Posted July 14, 2014 Advertisement (gone after registration) Never used JPG. DNG in Lightroom .... and WB behaviour is identical as far as I can tell between XV and T (I am using them both) which is not really surprising as I suspect the processing is identical .... with just the interface and the camera ergonomics being changed. Quote Link to post Share on other sites More sharing options...
Fotograph Posted July 15, 2014 Share #8 Posted July 15, 2014 Is anyone else having Auto White Balance problems with their T? I upgraded from an X Vario and I have been less than impressed with the T's output, comparatively. The colors and skin tones are just not right. While images are very sharp, they have lacked that warm and special Leica look that the XV had in spades. I shoot in Std mode. I have narrowed it down to the auto white balance being off - seems to consistently run on the cool side (both indoors & outdoors). Images become *much* improved with post processing by tweaking temperature, but I really wasn't expecting to tweak every image to this degree in post. This was not the case with the XV, which had the best OOC colors and skin tones I've ever seen. I know this is supposed to be a strength of the XV and T. Perhaps it's a limited problem with my particular camera. Seems to be a similar situation with the 23mm lens and the zoom for me. I would appreciate any input or advice you all may have. Many thanks! Hi, ist the problem solved or is your camera defective? It's the same with my Leica T, mostly cooler colors as it should be..... Quote Link to post Share on other sites More sharing options...
felixthecat Posted July 15, 2014 Share #9 Posted July 15, 2014 Do agree that the WB is slightly on the cold side. But I always shoot raw so not a problem at all. Quote Link to post Share on other sites More sharing options...
mjh Posted July 15, 2014 Share #10 Posted July 15, 2014 I haven’t noticed anything out of the ordinary about the T’s AWB. Quote Link to post Share on other sites More sharing options...
IkarusJohn Posted July 16, 2014 Share #11 Posted July 16, 2014 I rather like the AWB on mine (for what that is worth). Quote Link to post Share on other sites More sharing options...
